Synchronous machines – Motor Factory – Test environment
In accurate mode the sign of the reactive power, and the phase angle is not right.
The sign conventions are not respected for defining the reactive power and phase angle (ref.: FXM-16143 & FXM-16542).
Working point – Square wave – Forced I – Average computation of quantities.
The computation of average quantities like iron losses, the Joule losses in magnets, and torque is not executed over a full electrical period. That can lead to wrong results (ref.: FXM-14091).
Maximum speed computation
The estimation of the maximum speed is wrong for the tests “Working point - Sine wave – Motor - U-I” and “Working point - Sine wave – Motor - T-N” when the control mode MTPA is selected (ref.: FXM-10916). The computation is always performed by considering the MTPV command mode.
SMRSM - Working point – Sine wave – I, Ψ, N – Accurate computation mode with Skew
The computation failed in case of Skewed geometry with the accurate computation mode (ref.: FXM-16581).
