Volume: about
Volumes
Volumes can be built by Flux PEEC:
  • with the aid of automatic construction algorithm
    (automatic identification and creation)
  • by propagation from existing volumes with the aid of a transformation
  • by extrusion from existing faces with the aid of a transformation
Volumes built by Flux PEEC
The volumes built by Flux PEEC are the ones defined by planar faces. The types of volumes are presented in the table below:
Volume of following type is built …
automatic
    (command Build Faces)
  • by extrusion from faces (command Extrude faces
    with building option Add Volumes, Faces, Lines and Points)
  • by propagation of volumes (command Propagate volumes
