Conductors impedance application: post-processing quantities
Solving process: reminder
With the application Conductors impedance, the solving process requires two steps, as presented in the table below.
PEEC computation (independent on the application) |
computation of resistances and partial self-inductances (R, L) of each
element of the conductor, computation of partial mutual inductances (M) among all the parallel elements of the conductor |
Computation of the impedance |
reducing the electric scheme ⇒ values of the equivalent impedances at the level of the impedance probes |
Quantities
The quantities issued from computation at the level of the impedance probes are presented in the table below.
Quantity | Unit | Explanation | |
Self impedance (Zii) seen from the input of the probe i | complex scalar | Ω | Impedance of the set of conductors seen by the probe i when all other probes are replaced by an open circuit |
Transfer impedance (Zij) between the probe j and the probe i | complex scalar | Ω | Transfer impedance of the probe i to the probe j when all the probes, except the jth one, are replaced by open circuits |
These quantities can be exported in form of equivalent circuit towards SPICE, SABER, MODELICA, PORTUNUS or in form of table through a text file.
