Enable/Disable
Weight Analytics allows you to change the mapping of a Department to Functional View Nodes.
To enable or disable Functional View mapping:
  1. Click Functional Views > Data Acess > Department Func. View Mapping.
    The Department Functional View mapping page is displayed.
    For every Department and nodes of a selected Functional view, you can change the access role. The change will be applied to the selected node and all its descendants.
  2. Select a Department in the Department list.
  3. Select the required Functional View from the dropdown list.
  4. Select the required Functional View Node.
  5. Click Enable/Disable Func.View Node access.
