Standard inputs ––––--
No standard user input is needed.
Advanced inputs ––––--
No. comp. / cogging period
The computation of cogging torque versus the rotor angular position is performed using a Finite Element Modeling.
“No. comp. / cogging period” (Number of computations per cogging torque period) influences the accuracy of results and the computation time.
The default value is equal to 45. The minimum allowed value is 13. This default value provides a good compromise between the accuracy of results and computation time.
Max. harmonic order
The cogging torque is computed over one cogging torque period.
Harmonics are extracted from the frequency analysis (F.F.T. Fast Fourier Transform) of the cogging torque signal versus rotor angular position.
The order of harmonics displayed on bar graphs and in tables can be selected with this advanced user input parameter “Max. harmonic order” (Maximum harmonic order selected for visualization).
Note: From mathematical point of view, the maximum allowed harmonic order depends on the number of computations per electrical period. In case of too small number of computations per electrical period, the harmonic order considered will be lower than which user has set.
The default value is equal to 20. The minimum allowed value is 1.
Rotor initial position
The computations are carried out by considering a given initial relative angular position between the rotor and the stator.
This initial relative angular position of the rotor must be set in the field « Rotor initial position».
This relative angular position corresponds to the angular distance between the direct axis of the rotor north pole and the axis of the stator phase 1 (reference phase). The default value is equal to 0. The range of possible values is [-360, 360].
For additional information please refer to the section Rotor initial position (link).
Skew model – No. of layers
When the rotor magnets or the stator slots are skewed, the number of layers used in Altair Flux Skew environment to model the machine can be modified: “Skew model - No. of layers” (Number of layers for modelling the skewing in Flux Skew environment).
Note: When there is magnet step skew topology, the number of layers is defined at the design level.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient which adjusts the size of mesh elements inside the airgap. When the value of “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap, increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching points of the geometry), inside the Altair Flux software, is described as:
MeshPoint = (airgap) x (airgap mesh coefficient)
0.05 giving a very high mesh density and 2 giving a very coarse mesh density.
CAUTION: Be aware, a very high mesh density does not always mean a better result quality. However, this always leads to a huge number of nodes in the corresponding finite element model. So, it means a need for huge numerical memory and increases the computation time considerably.
The impact of the airgap mesh coefficient on resultant meshing is illustrated bellow:
Figure 1. Airgap mesh coefficient = 0.45 = default value
Figure 2. Airgap mesh coefficient = 1.0
Figure 3. Airgap mesh coefficient = 0.1
Figure 4. Airgap mesh coefficient = 0.1 (zoomed view)
