Hertz-Mindlin with JKR Model
The Hertz-Mindlin with JKR contact model works within the contact zone and allows you to model strongly adhesive systems, such as dry powders or wet materials.
Hertz-Mindlin with JKR (Johnson-Kendall-Roberts) Cohesion is a cohesion contact model that accounts for the influence of Van der Waals forces. In this model, the implementation of normal elastic contact force is based on the Johnson-Kendall-Roberts theory (Johnson, Kendal and Roberts 1971).
Hertz-Mindlin with JKR Cohesion uses the same calculations as the Hertz-Mindlin (no slip) contact model for the following types of forces:
  • Tangential elastic force
  • Normal dissipation force
  • Tangential dissipation force
JKR normal force depends on the overlap δ and the interaction parameter, surface energy γ as follows:
F JKR =−4 πγE*   a 3/2 + 4 E * 3 R * a 3 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGkbGaam4saiaadkfaaeqaaOGaeyypa0JaeyOeI0IaaGin amaakaaabaGaeqiWdahccaGae83SdCMaamyraiaacQcaaSqabaGcca aMc8UaamyyamaaCaaaleqabaGaaG4maiaac+cacaaIYaaaaOGaey4k aSYaaSaaaeaacaaI0aGaamyramaaCaaaleqabaGaaiOkaaaaaOqaai aaiodacaWGsbWaaWbaaSqabeaacaGGQaaaaaaakiaadggadaahaaWc beqaaiaaiodaaaaaaa@4DA1@
δ= a 2 R * − 4πγa E * MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiTdqMaey ypa0ZaaSaaaeaacaWGHbWaaWbaaSqabeaacaaIYaaaaaGcbaGaamOu amaaCaaaleqabaGaaiOkaaaaaaGccqGHsisldaGcaaqaamaalaaaba GaaGinaiabec8aWjabeo7aNjaadggaaeaacaWGfbWaaWbaaSqabeaa caGGQaaaaaaaaeqaaaaa@4401@
Here, E* is the equivalent Young’s modulus, and R* is the equivalent radius defined in the Hertz-Mindlin (no slip) Model section.
The normal force is a function of normal overlap. The Hertz-Mindlin with JKR cohesion model results are compared with the Hertz-Mindlin (no slip) model results. Negative overlap is the gap between two separated particles.
The EDEM JKR normal force follows the same solution of the above equations for both loading and unloading phases. The figure shows the typical plot of JKR normal force as a function of normal overlap.
For γ = 0, force turns into Hertz-Mindlin normal force:
F Hertz = 4 3 E * R * δ 3 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGibGaamyzaiaadkhacaWG0bGaamOEaaqabaGccqGH9aqp daWcaaqaaiaaisdaaeaacaaIZaaaaiaadweadaahaaWcbeqaaiaacQ caaaGcdaGcaaqaaiaadkfadaahaaWcbeqaaiaacQcaaaaabeaakiab es7aKnaaCaaaleqabaWaaWbaaWqabeaadaWcaaqaaiaaiodaaeaaca aIYaaaaaaaaaaaaa@452F@
This model provides attractive cohesion forces even if the particles are not in physical contact. The maximum gap between particles with non-zero force is defined as:
δ c =− 4πγ a c E * + a c 2 R * MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiTdq2aaS baaSqaaiaadogaaeqaaOGaeyypa0JaeyOeI0YaaOaaaeaadaWcaaqa aiaaisdacqaHapaCcqaHZoWzcaWGHbWaaSbaaSqaaiaadogaaeqaaa GcbaGaamyramaaCaaaleqabaGaaiOkaaaaaaaabeaakiabgUcaRmaa laaabaGaamyyamaaBaaaleaacaWGJbaabeaakmaaCaaaleqabaGaaG OmaaaaaOqaaiaadkfadaahaaWcbeqaaiaacQcaaaaaaaaa@483D@
a c = 9πγ R *2 2 E * 3 4 − 1 2 1 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyamaaBa aaleaacaWGJbaabeaakiabg2da9maadmaabaWaaSaaaeaacaaI5aGa eqiWdaNaeq4SdCMaamOuamaaCaaaleqabaGaaiOkaiaaikdaaaaake aacaaIYaGaamyramaaCaaaleqabaGaaiOkaaaaaaGcdaqadaqaamaa laaabaGaaG4maaqaaiaaisdaaaGaeyOeI0YaaSaaaeaacaaIXaaaba WaaOaaaeaacaaIYaaaleqaaaaaaOGaayjkaiaawMcaaaGaay5waiaa w2faamaaCaaaleqabaWaaWbaaWqabeaadaWcaaqaaiaaigdaaeaaca aIZaaaaaaaaaaaaa@4B99@
For δ < δc , the model returns zero force. The maximum value of the cohesion force occurs when particles are not in physical contact and the separation gap is less than δc. The value of maximum cohesion force, called pull-out force, is defined as:
F p u l l o u t = − 3 2 π γ R * MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGWbGaamyDaiaadYgacaWGSbGaam4BaiaadwhacaWG0baa beaakiabg2da9iabgkHiTmaalaaabaGaaG4maaqaaiaaikdaaaGaeq iWdaNaeq4SdCMaamOuamaaCaaaleqabaGaaiOkaaaaaaa@463E@
Friction force calculation is different from the Hertz-Mindlin (no slip) model. In that, it depends on the positive repulsive part of JKR normal force. As a result, the EDEM JKR Friction model provides greater friction force when the cohesion component of the contact force is higher. The importance and advantages of this Friction Force model correction in the presence of strong cohesive forces was noted and illustrated in (Baran, et al. 2009), (Gilabert, Roux and Castellanos 2007).
Although this model was designed for fine, dry particles, it can be used to model wet particles. The force needed to separate two particles depends on the liquid surface tension γc and the wetting angle θ:
F pullout =2π γ s cos(θ) R i R j MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGWbGaamyDaiaadYgacaWGSbGaam4BaiaadwhacaWG0baa beaakiabg2da9iaaikdacqaHapaCcqaHZoWzdaWgaaWcbaGaam4Caa qabaGcciGGJbGaai4BaiaacohacaGGOaGaeqiUdeNaaiykamaakaaa baGaamOuamaaBaaaleaacaWGPbaabeaakiaadkfadaWgaaWcbaGaam OAaaqabaaabeaaaaa@4DDF@
Equating the above force to JKR max force allows JKR surface energy parameter estimation if the EDEM particle size is not scaled.
Interaction Configurable Parameters Position
Particle to Particle, Particle to Geometry. Click + to add cohesion to particle-particle or particle-geometry interactions. Set the surface energy for each interaction. Surface energy is a property of the materials ability to retain moisture/charge on its surface. The amount of surface energy influences the adhesion of the material. The SI units of surface energy are J/m². Last
  1. In the Creator Tree, select Physics.
  2. Select the required interaction from the Interaction dropdown list.
  3. Click the + icon and then select Hertz-Mindlin with JKR Cohesion.
  4. Click the icon to define the contact model parameters.
Note: It is not recommended to use this contact model with particle contact radius 'ON' since this will result in an attractive force before a physical contact is made (see the Hertz-Mindlin with JKR Version 2 model).
