_sens.#.mvw file
The _sens.#.mvw file is a HyperView session file.
File Creation
This file is created when an optimization is performed. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
This file is a HyperView session file and may be opened from the File menu in HyperView or HyperGraph. The file automatically creates a histogram for each of the results contained in the .#.sens file. The plots are grouped so that design variable sensitivities for different responses are given on separate pages.
- The # in the file name is the iteration number.
