.els.# file
The .els.# file is a Patran 2.5 ASCII format results file.
File Creation
This file is created when the Patran format is chosen and topology design variables are present. (See documentation for the I/O Option OUTPUT).
File Contents
| Result | Description |
| Density | Density results from
                                topology optimizations.  Output is controlled by the I/O Option DENSRES.  |
- One such file is created for each iteration where the I/O Option DENSRES requests topology results to be output.
 - The # in the file name is the iteration number.
