The .disp file is an OptiStruct
        ASCII format results file.
        File Creation
            This file is created when the OPTI, OS or BOTH formats are chosen. (See documentation
                for the I/O Option OUTPUT).
File Contents
                            | Result |
                            Description |
                            | Acceleration |
                            Acceleration results from
                                frequency response analysis and linear transient analysis.  Output
                                    is controlled by the I/O Option ACCELERATION.
                            | Displacement |
                            Displacement results from
                                linear static, inertia relief, frequency response analysis, and
                                linear transient analysis.  Output is controlled by the I/O Option
                                        DISPLACEMENT.
                            | Eigenvector |
                            Eigenvector results from
                                normal modes and linear buckling analysis.  Output is controlled
                                    by the I/O Option DISPLACEMENT.
                            | Velocity |
                            Velocity results from
                                    is controlled by the I/O Option VELOCITY.
File Format
The displacement file has the following format:
                                | For each iteration, the following header is
                                    used: |
                                iter |
                                Iteration |
                                Numids |
                        - Data
                        - Description
                        - iter
                        - Keyword identifying that the next field is the iteration number.
                        - Iteration
                        - The iteration number.
                        - Numids
                        - The number of linear static subcases plus the number of calculated
                            normal and buckling modes.
                                | Within the iteration section, the following header
                                    is used for each linear static subcase, normal or linear
                                    buckling mode, or direct modal frequency response: |
                                LCID |
                                Numnod |
                                Freq |
                                Result:
                                        SPCcase
                                    (Datatype) |
                        - Data
                        - Description
                        - LCID
                        - Output ID for the subcase or mode. This is not necessarily the same as
                            the subcase ID defined in the input data.
                        - Numnod
                        - Number of grids in the model.
                        - Freq
                        - Frequency or Buckling eigenvalue (1.0 for static subcases).
                        - Result
                        - Keyword declaring the result type given.
                        - DISP indicates displacement result.
                        - VELO indicates a velocity result (for frequency
                            response analysis only).
                        - ACCE indicates an acceleration result (for frequency
                        - SPCcase
                        - SPC set identification number for linear static, inertia relief, or
                            frequency response subcases or 1 for eigenvectors.
                        - Datatype
                        - Keyword indicating the type of subcase involved.
                        - LOAD declares data is from a static subcase.
                        - EIGV declares data is from a normal modes subcase.
                        - BKLV declares data is from a linear buckling
                            subcase.
                        - DFRQ declares data is from a direct frequency response
                            subcase.
                        - MFRQ declares data is from a modal frequency response
                            subcase.
                                | Within the subcase or mode section, the following
                                    information is provided for each node: |
                                NID |
                                X
                                        disp |
                                Y
                                        disp |
                                Z
                                        disp |
                        - Data
                        - Description
                        - NID
                        - Node identification number.
                        - X
                        - X displacement of the node.
                        - Y
                        - Y displacement of the node.
                        - Z
                        - Z displacement of the node.
            The displacement file has the following format for linear transient analysis:
                                | For each
                                    iteration, the following header is used: |
                                iter |
                                Iteration |
                        - Data
                        - Description
                        - iter
                        - Iteration
                                | Within the
                                    iteration section, the following header is used for each
                                    transient analysis subcase: |
                                | Subcase |
                                Id |
                                Label |
                                | Time |
                                Time |
                                | Result Type |
                                Domain |
                                [Format] |
                        - Data
                        - Description
                        - Id
                        - Output ID for the subcase. This is not necessarily the same as the
                        - Label
                        - Subcase label.
                        - Time
                        - Time increment information.
                        - Format
                        - Complex, Real, Imaginary, Phase, and so on.
                        - Result Type
                        - DISP indicates displacement results.
                        - VELO indicates a velocity result.
                        - ACCE indicates an acceleration result.
                                | Within the subcase section, the following information is
                                    provided for each grid: |
                                GID |
                                X |
                                Y |
                                Z |
                                RX |
                                RY |
                                RZ |
                        - Data
                        - Description
                        - GID
                        - Grid identification number.
                        - X
                        - X value of the grid.
                        - Y
                        - Y value of the grid.
                        - Z
                        - Z value of the grid.
                        - RX
                        - RX value of the grid.
                        - RY
                        - RY value of the grid.
                        - RZ
                        - RZ value of the grid.
                - The I/O Option Previously Supported Results controls
                    the frequency of output for analytical results during an optimization.
