The _s#_d.frf file is an OptiStruct
        ASCII format results file.
File Creation
This file is only created for frequency response subcases. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
                            | Result |
                            Description |
                            | Displacement |
                            Displacement results from
                                frequency response analyses.  Output is controlled by the I/O
                                    Option DISPLACEMENT.
File Format
If the real and imaginary format was selected on the
DISPLACEMENT card, the
                file starts with the following header:
                                | Frequency"REA | X
                                    Trans"IMA | X Trans"REA | Y Trans"IMA | Y Trans"REA | Z
                                    Trans"IMA | Z Trans |
If the phase and magnitude format was selected on the
                                | Frequency"PHA | X
                                    Trans"MAG | X Trans"PHA | Y Trans"MAG | Y Trans"PHA | Z
                                    Trans"MAG | Z Trans |
In either case, the results are grouped by node with results for different nodes separated by a
                blank line. The format of each line after the header is:
                                Frequency |
                                X-rl/ph |
                                X-im/mag |
                                Y-rl/ph |
                                Y-im/mag |
                                Z-rl/ph |
                                Z-im/mag |
                        - Data
                        - Description
                        - Frequency
                        - Is the frequency at which results are calculated.
                        - X-rl/ph
                        - Is either the real component in the x-direction or the phase angle in
                            the x-direction component.
                        - X-im/mag
                        - Is either the imaginary component in the x-direction or the magnitude in
                        - Y-rl/ph
                        - Is either the real component in the y-direction or the phase angle in
                            the y-direction component.
                        - Y-im/mag
                        - Is either the imaginary component in the y-direction or the magnitude in
                        - Z-rl/ph
                        - Is either the real component in the z-direction or the phase angle in
                            the z-direction component.
                        - Z-im/mag
                        - Is either the imaginary component in the z-direction or the magnitude in
            - The # in the file
                name is the user-defined subcase ID from which these results are obtained.
            - The _freq.mvw
                HyperView script file automatically creates plots for
                the results contained in this file.
