_expl.cntf file
An OptiStruct ASCII format results file.
File Creation
This file is created when the OPTI format is selected in the CONTF I/O Options Entry, in an Explicit Dynamic Analysis (ANALYSIS=NLEXPL).
File Contents
- Result
 - Description
 - Contact forces
 - Contact force results from explicit dynamic analysis (with contact). This file is created when format = OPTI is specified in the CONTF I/O Option.
File Format
| Subcase ID | Load ID | Explicit Time Step | Subcase Label |
| CONTACT INTERFACE: TOTAL FORCE ACTING ON MAIN SURFACE (BASIC SYSTEM) AND TOTAL CONTACT AREA | |||||
| CONTACT# | FORCE-X | FORCE-Y | FORCE-Z | MAGNITUDE | AREA |
| CONTACT# | Normal Force | Tangent Force | |||
- Data
 - Description
 - CONTACT #
 - Contact Interface identification number (CTID on the CONTACT Bulk Data Entry).
 - FORCE-X
 - Component of the total contact force along the X-axis of the Basic system.
 - FORCE-Y
 - Component of the total contact force along the Y-axis of the Basic system.
 - FORCE-Z
 - Component of the total contact force along the Z-axis of the Basic system.
 - MAGNITUDE
 - Magnitude of the total contact force acting on the main surface.
 - AREA
 - Area of main surface under contact.
 - Normal Force
 - Resultant force along the normal direction to the main surface.
 - Tangent Force
 - Resultant force along the tangential direction to the main surface.
- The output frequency of the results in this file can be controlled by the value of NINT field in the NLOUT entry.
