spotweld
Specify defaults for the spotweld check functionality of Model Verification.
General Settings
- angle
 - Feature angle of the faces of FE.
 - Slide-number
 - The starting number shown in the top corner of the PowerPoint file.
Figure 1. - input
 - Initial directory for the Input file path.
 - output
 - Initial directory for the report output path.
 - action
 - User action type to be executed.
- Check
 - Only intersection check will be executed, no reports.
 - Report
 - Only Reports will be generated from the previous check.
 - Both
 - Check and Report generation will be executed in a sequence.
 - mode
 - Default options for Run type.
- interactive
 - Check executed in the front ground HyperMesh session
 - background
 - Check executed in the background HyperMesh sessions. Automatic restart executed. If errors occur, the errors will be displayed in the browser as "Crash" keyword.
 - vip-format
 - Space or 8-digit separated format.
 - resolveconflictingpid
 - 5 digits or 7 digits format correction.
 - realize-check
 - Ignores failed spot welds during the check.
 - allow-multiple-issues
 - All checks on all spot welds. There may be issues on the same welds.
 - extract-spot-cad
 - Converts CAD points/solids to the spot weld file. A copy of the spot weld vip file will be stored in the CAD folder.
 - extract-spot-cad-option
 - Converts point/solid entities to spot weld file.
 - realize-tolerance (tol)
 - Allows searching the nearest spot on the same layer or different layer
                            or bot/all duplications.
Closest
- do-check
 - Turn OFF or ON the check
 - Tolerance (tol)
 - Distance between two spot welds less than/equal to this tolerance are
                            reported as duplicates. Distance is calculated after projecting to
                            normal direction.
Figure 3. - checktypes
 - Allows searching duplicate spot welds on the same layer (same weld plates) or different layers or bots/all duplications.
Figure 4.
Gap
- do-check
 - min
 - Minimum gap between Spot location and the weld plates.
Figure 5. - max
 - Maximum gap to be considered between Spot location and the weld plates. This value is added to filter some spotwelds which are too far from the model.
Figure 6.
Single-Layer
- do-check
Figure 7.
Multi-Layer
- do-check
 - threshold
 - Maximum allowed spot weld layers.
Figure 8.
hm-issue
- do-check
- Tol
Figure 9.
Parallel-flanges
- do-check
 - angle
 - Maximum angle between two plates at spot location.
Figure 10. - max-gap
 - Maximum physical gap between two plates at Spot location.
Figure 11.
Incorrect-Location
- do-check
 - min-distance (min)
 - Minimum distance allowed from feature-line to the spot location.
Figure 12.
Figure 13.
Few-Connections
- do-check
 - Proximity (a)
 - Search tolerance for realizing spot weld on the flanges, it is global pitch.
 - pitch-spacing (b)
 - Average pitch distance for creating spot weld on flange.
 - pitch-offset (c)
 - End offset distance on both side of the flange.
 - pitch-edge-distance (d)
 - Offset distance from the edge of the flange.
 - search tolerance (e)
 - Tolerance for searching Virtua connectors from existing connectors created from the above parameter.
 - hole-diameter (f)
 - Search tolerance for finding nearest Bolt holes to avoid finding the
                                issue.
Figure 14.
Figure 15.
Flange-gap
- do-check
 - limit
 - +/- ratio of shortest gap between flanges at connector to average
                            component thickness value. It is also % of deviation.
Figure 16.
Figure 17.
Intersection
- do-check
 - spot-layers
 - Maximum number of layers considered for this check.
Figure 18.
Figure 19.
Fillets
- Fillet identification angle
Figure 20. - do-check
 - fillet-connelem-tol
 - Search tolerance for searching the nearest fillet edges to the
                                connector.
Figure 21.
Figure 22.
Reflect
- do-check
 - reflect-plane
 - Reflecting plane for the model which the spot welds are reflected and
                            checked again for realization.
Figure 23. - origin
 - Origin value. (for XY plane, origin is constant Z value)
Failed spot welds are reflected at reflect-plane and re-realized, if successful in realization, it is identified as an issue.
Figure 24.
surrounding
- do-check
 - spot-layers
Figure 25.
Figure 26.
