Report outputs and visualization configuration.
        Settings
                        - advance
                        - true = Advance style report with MultiCPU, false = Normal style report
                            with 1CPU.
                        - Supported values: true
                        - Convert PPT to PDF
                        - Converts PowerPoint slide to PDF file.
                        - avoid_duplicate_slide
                        - true = duplicate slides avoided, #duplicate issues shown under instance,
                            false = all of the issues for single pairs will be reported.
                        - Fullmodel-image
                        - Full model image will be shown in wireframe in all Verification slides
                            at the left top image. This takes additional time for generating
                            wireframe imaged.
                        - Default/Allowed : OFF/ON
                        - imageType-Verification
                        - To reduce slide size the JPG format can selected.
                            By default, the h3d option allows you to view the
                            results in 3D view.
                        - Default/Allowed :
                            h3d/jpeg
            visualization settings define configurations related to visualization.
                        - bg
                        - Background colors to be used for creating H3D files and images.
                                    - h3d
                                    - The background color to be used when creating H3D files.
                                    - Supported values: 255, 255, 255, 255, 255 255
                                    - jpg
                                    - The background color to be used when creating JPG image
                                        files.
                                    - Supported values: 49, 111, 255, 95, 181 266
                        - color
                        - Default colors for various check results.
                                    - comparison
                                    - Default colors for comparison check.
                                                - master
                                                - Color number for Master component.
                                                - Supported values: Color Number, ex - 12
                                                - slave
                                                - Color number for Slave component.
                                                - Supported values: Color Number, ex - 6
                                                - unmatched
                                                - Color number for unmatched entities.
                                                - Supported values: Color Number, ex - 33
                                                - WT-Calculation
                                                - Option to display the weight in the reports.
                                                  true - will enable the display and false - will
                                                  disable the display.
                                                - Supported values: true or false
                                                - WT-Comparison
                                                - Option to display the delta weight in the
                                                  reports. true - will enable the display and false
                                                  - will disable the display.
                                                - WT-Graph
                                                - Option to display the weight graph in the
                                                - WT-Graphtype
                                                - Option to choose the waterfall graph type. The
                                                  values 0 / 1 / 2 / 3 represent the available graph
                                                  types.
                                                - Supported values: 0, 1, 2, 3
                                                - WT-Scalefactor
                                                - Multiplies the weight with the specified
                                                  multiplication factor.
                                                - Supported values: A desired multiplication
                                                  factor. Default is 1.
                                    - intersection
                                    - Default colors for intersection test.
                                                - master
                                                - Supported values: Color Number, ex - 55
                                                - slave
                                                - Supported values: Color Number, ex - 21
                                                - master-intersecting
                                                - Color number for intersecting elements on the
                                                  master component.
                                                - Supported values: Color Number, ex - 62
                                                - slave-intersecting
                                                  slave component.
                                                - Supported values: Color Number, ex - 47
                        - transparency
                        - Transparency settings.
                                    - intersection
                                    - Transparency settings for intersection check.
                                                - master
                                                - The choice to turn on transparency for the
                                                  master component. True enables transparency and
                                                  false makes the component opaque.
                                                - slave
                                                - The choice to turn on transparency for the main
                                                  component. True enables transparency and false
                                                - level
                                                - The level of transparency on a scale of 0 to 10.
                                                  0 being no transparency and 10 being completely
                                                  transparent.
                                                - Supported values: Number, ex - 3
                                    - comparison
                                    - Transparency settings for comparison.
                                                - level-assembly
                                                - The level of transparency on a scale of 0.5 to
                                                  7, with 0.5 being high transparency and 7 being
                                                  less transparent.
                                                - Assembly (ON/OFF) converts matched entries into
                                                  transparency mode in the first page of the PPT
                                                  (OFF by default).
                        - intersection
                        - Visualization related settings for intersection reporting.
                                    - cross
                                    - Settings related to Cross.
                                                - length
                                                - The length of the cross as a percentage of the
                                                  model length.
                                                - Supported values: Percentage, ex - 8
                                                - width
                                                - The width of the cross as a percentage of the
                                                  model length.
                                                - Supported values: Percentage, ex - 0.15
                                    - sphere
                                    - Sphere dimension for the sphere.
                                                - radius
                                                - The radius of the sphere as a percentage of the
                                                  cross length.
                                                - Supported values: Percentage, ex - 2
                                                - color
                                                - The color to be used for the sphere by
                                                  specifying the corresponding color number from the
                                                  palette.
                                                - Supported values: Percentage, ex - 3
                                    - reportgroup
                                    - multiple = Multiple slides in single PPT.
                                    - Supported values: single / multiple
                        - spotweld
                        - Setting related to spot weld check reporting.
                                    - cross
                                    - Settings related to cross.
                                                - length
                                                  model length.
                                                - width
                                                  model length.
                                    - sphere
                                                - radius
                                                - The radius of the sphere as a value in model
                                                  units.
                                                - color
                                                  palette.
                                    - clip
                                    - Clip dimensions.
                                                - radius
                                                - Attribute - TBD.
                                                - Supported values: Value in model units, ex -
                                                  150
                        - hvp
                        - DO NOT CHANGE.
                        - Supported values: Text Value, ex – HvpLeft, HvpRight
                                    - bordercolor
                                    - Border color of the HVP title note.
                                    - titlefontsize
                                    - Title font size.
                                    - titlecolor
                                    - Title Color.
                                    - titlefont
                                    - Title Font.
            comparisonunified settings:
                        - max-record
                        - Supported values: 50
                        - template
                        - The file name of the MS PowerPoint template to be used for reporting.
                        - Supported values: File name, ex –
                                “Template_compare.potx”
                        - template-sheet
                        - Name given to template.
                        - skip-assembly-slide
                        - Skip the assembly image in the first slide of MS PowerPoint.
                        - skip-thumbnail-slide
                        - Parameter to skip second page of Comparison PowerPoint and Excel
                            report.
                        - skip-thumbnailassemblyimage
                        - Parameter to skip assembly image in Comparison PowerPoint
                            (checkbox).
                        - template-ppt
                        - Path of the power point template.
                        - percentage-sequence
                        - This is the parameter for arranging the order of thumb nail images of
                            components in the PowerPoint.
                        - Supported values:
                                - 0 – Default order.
                                - 1 – Match percent in decreasing order.
                                - 2 – Part IDs in decreasing order.
                        - resultslide
                        - This is the parameter to get the default multiple slides for
                            multi-variant comparison or to get single slide which shows the best
                            match result.
                        - Supported values:
                                - Default – Multiple slides are shown.
                                - Best match – Best matches for each components are shown from
                                    the multiple variants.
                        - threshold_report
                        - This is an intermediate percentage value to be given between threshold
                            value and maximum value. The components having match percent value
                            between threshold and threshold_report value is shown in green color and
                            the components with value between threshold_report and maximum value in
                            gray color.
                        - result-review
                        - Result display setting after comparison check is completed. The
                            following options can be selected to display unmatched entities on
                                graphics.
                                    - tempNodes
                                    - Displays unmatched area as temp nodes.
                                    - tempComps
                                    - Displays unmatched area as elements in red color.
                                    - tempComps+Node XYZ
                                    - Displays unmatched area as elements in red and exports
                                        unmatched nodes in a text file working folder.
                                    - legend-detailed
                                    - Applicable for Quick Comparison flag ON, unmatched elements
                                        are shown in red color.
                                    - legend-overview
                                        are not shown in red color showing high level results.
                        - range-legend-level
                        - Applicable for Quick Comparison flag ON. Comparison legend left tab
                            Ranged's number of levels are controlled by these values. 0 to 100%
                            values are split by these values. An example in case of 30-90% match
                            results exist, 90-30/7=8.57 splits will be shown.
                        - threshold-ranges
                        - Applicable for Quick Comparison flag ON. Comparison legend right tab
                            Discrete's levels are controlled by these values. The accepted value is
                            from 30 to 99.9 with spaces between values.
                        - Default: 50 80 90 (result legend will display 0-30, 30-50, 50-80, 80-90,
                            90-100. Specific range will be ignored if no results found).
                        - thumbnail-assemblyImageColor
                        - Applicable for quick Comparison flag ON. Part color shown inside the
                            assembly thumbnail image, it is in the 2nd page of the Powerpoint
                            report.
                        - Default: Dark blue.
                        - thumbnail
                        - Text displayed below thumbnail image, supports PID or Part Name. It is
                            in the 2nd page of the Powerpoint report.
                        - Default: PID.
                        - Show unmatched ribs
                        - Parameter to display unmatched surfaces for the Honeycomb kind of Rib
                            pattern. The default is OFF.
                        - Q-Compare
                        - This option can be used if comparison performance is main concern. It
                            reads Base and Variant model data and compares them on the screen.
                            Interface and workflow is similar to default comparison with few
                            limitations.
                                    - Assembly-View
                                    - If this option is ON, Matched/Unmatched parts color can be
                                        controlled for the Assembly images in the summary report.
                                        Parts unmatched/matched color can be controlled using these
                                        check box color options.
                                    - Default: OFF/ON.
            Intersection settings are related to reporting for intersection check.
                        - max-slide
                        - Maximum number of slides to be included in the PPT file.
                        - Supported values: Number (for example, 50).
                        - ignore_part_Instance
                        - Ignores part instances from intersection check and report. This is
                            applicable if the number of parts in the model are more then 300.
                        - Default: ON.
                        - ignore_name_Instance
                        - Ignores parts if their Part Names and Part Number are almost the same
                            from intersection check and report. This is applicable if the number of
                        - Default: ON.
                        - display_intersection_depth
                        - Displays intersection depth value in a text box inside HyperView player.
                        - Default: OFF.
                        - text-static
                        - You can enter the information.
                        - Supported
                            values:
object: “Text left”
description: “Intersection Check”
object: “Text right”
description: “Answer:”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
            spotweld settings:
                        - max-slide
                        - Supported values: Number,ex-50
                        - text-static
                        - Supported values:
object: “Text left”
description: “Spotweld Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
            spot-comparison settings:
                        - max-slide
                        - template
                            reporting.
                            “Template.potx”
                        - text-static
                        - Supported values:
object: “Text left”
description: “Spotweld Comparison”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
            freepart settings:
                        - max-slide
                        - template
                            “Template.potx”
                        - layout
                        - DO NOT CHANGE.
                        - Supported values: Number, ex – 2
                        - text
                                    - description
                                    - DO NOT CHANGE.
                                    - Supported values: Text Value, ex – “Text1”
                                    - project
                                    - DO NOT CHANGE.
                                    - Supported values: Text Value, ex – “Info1”
                                    - id
                                    - DO NOT CHANGE.
                                    - Supported values: Text Value, ex – “Info7”
                                    - date
                                    - DO NOT CHANGE.
                        - text-static
                        - Supported values:
object: “Text left”
description: “Connection Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
