connection
Connection check configurations.
GUI Default Settings
- slide-number
 - Initial slide # displayed on the report.
 - action
 - Action items.
 - mode
 - Execution mode. Interactive mode will be slower than background mode.
 - input
 - Initial director for CAD Input.
 - output
 - Initial director for results output.
Hole Detection
- min-diameter
 - Minimum diameter for surface hole recognition. Holes below this diameter will be ignored.
 - max-diameter
 - Maximum diameter for surface hole recognition. Holes above this diameter will be ignored.
 - min-nodes
 - Minimum number of nodes to recognize FE hole. Holes with nodes less than this number will be ignored.
 - max-nodes
 - Maximum number of nodes to recognize FE hole. Holes with nodes greater than this number will be ignored.
 - adjacent-tolerance
 - Distance to judge duplicate holes for the same plate. If the Holes to Holes distance is less than this value it is considered as a duplicate hole.
Free Hole
- do-check
 - Turn OFF or ON the check.
 - elem-adj-bbox-tolerance
 - Search tolerance for searching nearest bolts/nuts from the hole
                                center.
freeboltnut
- do-check
 - bolt-box-tolerance
 - Search tolerance for searching nearest plates from the bolt outer
                                surfaces.
Figure 3. - nut-box-tolerance
 - Search tolerance for searching nearest plates from the nut outer
                                surface.
Figure 4. - allowed-plate-comps
 - These named parts will not be considered as plates.
Figure 5.
bolthole-mismatch
- do-check
 - input-type
 - Continuous CAD lines or CAD solids.
 - centernode-search-tolerance
 - Search tolerance for searching holes from bolt CAD surface.
Figure 6. - elem-adj-bbox-tolerance
 - Tolerance for searching nearest plates from the bolt outer surface.
Figure 7. - min-dist
 - Allowable mismatch distance between bolt axis and hole axis.
Figure 8. - max-dist
 - Maximum search distance between bolt axis and the hole axis.
Figure 9.
nuthole-mismatch
- do-check
 - input-type
 - Search tolerance for searching holes from bolt/nut CAD surface.
Figure 10. - elem-adj-bbox-tolerance
 - Tolerance for searching nearest plates from the nut outer surface.
Figure 11. - min-dist
 - Allowable mismatch distance between nut axis and hole axis. If the
                            mismatch is less than this value issues will not be reported.
Figure 12. - max-dist
 - Maximum search distance between nut axis and the hole axis. If the mismatch is greater than this value issues will not be reported.
Figure 13.
boltnut-mismatch
- do-check
Figure 14. - threshold-angle
 - Allowable angle between center axis of bolt and the nut. More than this
                            angle, the check will be ignored for that pair of connection parts.
Figure 15. - min-dist
Figure 16. - max-dist
 - Maximum search distance between nut axis and the hole axis. If the mismatch is greater than this value, issues will not be reported.
Figure 17.
boltnutsize-mismatch
- do-check
 - Tolerance for searching nearest bolt, plates from the nut outer
                                surface.
Figure 18. - min-dist
Figure 19. - min-nut-tol-bolt-ratio
 - Allowable minimum ratio between bolt and nut size. If the ratio is less
                            than this value the issue is reported.
Figure 20. - max-nut-tol-bolt-ratio
 - Allowable maximum ratio between bolt and the nut size. If the ratio is
                            greater than this value the issue is reported.
Figure 21.
Figure 22.
holes-mismatch
- do-check
 - min-dist
                            mismatch is less than this value the issues will not be reported.
Figure 23. - max-dist
 - Maximum search distance between hole center node axis.
 - Tolerance for searching nearest plates from the hole center.
Figure 24. - elem-adj-bbox-tolerance
Figure 25.
Figure 26.
holespair-mismatch
- do-check
Figure 27. - centernode-search-tolerance
Figure 28.
Figure 29.
Clip-mismatch
- do-check
 - input-type
 - Search tolerance from center clip to holes center.
Figure 30. - min-dist
 - Allowable mismatch distance between clip axis and hole axis.
Figure 31. - max-dist
 - Maximum distance between clip axis and the hole axis. Greater than this value the clip parts are ignored in the check.
Figure 32.
Arc/Seam/Adhesive/Seal/Hemming -mismatch
- do-check
 - input-type
 - elem-adj-bbox-tolerance (tol)
 - Search tolerance for finding the nearest weldable plates. If less than
                            two parts are found the issue is reported.
Figure 33. - min-dist
 - Minimum distance between arc weld to the nearest parts. If less than two
 - max-dist
 - Maximum distance between weld lines to the nearest parts.
Finds shape mismatch between the weld lines against the plates with the given min and max distance.
Figure 34.
