Rename Parts
Rename and set PIDs for all parts.
Part name and PIDs are extracted from file name displayed in Representation File column. For CAD inputs it is automatically executed during Intersection or Comparison.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
Use the Renumber tool to review and organize the IDs of model entities.
Change the order of named entities in database.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Scenarios are a mechanism to apply controls to engineering entities.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Verification Browser to inspect CAD data supplied from your design or CAD team.
Use the Comparison Browser to compare and identify the topology difference between two models/part assemblies/parts.
Import a model using Model Verification.
Perform various model checks in the Verification Browser.
Overview of various settings that can be configured for Model Verification.
Save Representations in the input folder.
Configure any part.
Merge comparison Excel reports and append user-defined metadata values.
Review the selected Part Assembly/Part in HyperView Player.
Review the selected Part Assembly/Part in HyperMesh graphics.
Export part representations.
Renumber PIDs for all parts.
Get the count of the selected Part Representations.
Group parts based on AI code and shape-based approach.
Run Model Verification operations in batch mode.
Limitations of the Model Verification tool.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
Define vectors in 3D space.
Define physical and mathematical characteristics of parts.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
Use the curve editor to create and plot XY curves.
The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
ON THIS PAGE
ON THIS PAGE
