names
Naming conventions used in various Model Verification Modules.
Settings
- module
 - Name settings for the modules within Model Verification.
- comparison-base
 - Identify FE Model in CAD-FE Comparison.
 - Supported values: “*base_model*”
 - spotweld
 - Naming pattern for component to be identified as spot weld component.
 - Supported values: “*-w-*”
 - part
 - Naming conventions for components.
- connection
 - Naming convention for classifying the component as various connecting components.
- bolt
 - Supported values: “*bolt*”, “!*plate*”
 - nut
 - Supported values: “*nut*”, “!*plate*”
 - clip
 - Supported values: “*clip*”
 - rivet
 - Supported values: “*rivet*”
 - stud
 - Supported values: “*stud*”
 - screw
 - Supported values: “*screw*”, “*scr*”
 - pin
 - Supported values: “*pin*”
 - arc
 - Supported values: “*arc*”, “*weld*”, “!*bolt*”, “!*nut*”
 - spot
 - Supported values: *spot*
 - other
 - Supported values: “*”, “!101-*”, “!102-*”, “!103-*”, “!104-*”
 - unwanted
 - Supported values: “f/j_boot”, “f/j_b/band”, “s/j_boot”, “s/j_b/band”, “*bane*”, “*cable*”, "*fulcrum*”, “*spring*”, “*surf*”, “*valve*”“*wstrip*”, “*zone*”
