VDAFS Reader
Supported Entities
- POINT
 - LINE
 - PLANE
 - PSET
 - MDI
 - CIRCLE
 - CURVE
 - SURF
 - FACE
Import Options
| Value | Description |
double |
              A negative value (default) indicates that the curves are being split at C1
                  discontinuities. A positive value indicates that curves are being split at G1 discontinuities with an angle greater than the given value (expressed in radians).  |
double |
              A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
Parts |
              Generate a full part-based hierarchy. |
BOMOnly |
              Generate an empty part-based hierarchy. |
TreeOfComponents |
              Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
              Consolidate hierarchy into a single part. |
on |
              Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
              Merge edges together during the import cleanup phase (default). |
on |
                 Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.  |
off |
              Import the model in the normal fashion (default). |
on |
              Import free curves (wireframe entities) into the model (default). |
off |
              Do not import free curves. |
on |
              Import free points into the model (default). |
off |
              Do not import free points. |
on |
              Generate metadata with the original CAD hierarchy within the
                part.
off |
              Do not generate metadata with the original CAD hierarchy within the part (default). |
string |
              The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details.  |
Any positive real number. |
              The reader considers this tolerance as the parametric tolerance used to process the CAD data. The default value is 1.00E-06. |
on |
              Treat each surface as found in the CAD file (planes/NURBS). |
off |
              Convert planes into NURBS surfaces. |
preferred |
              Convert NURBS surfaces to planes if they are within the object space tolerance of being planar (default). |
double |
              Define the model scaling factor during import. Default is 1.0.  |
Body |
              Generate body-based component (default if
                  CreationType=Parts). |
Part |
              Generate part-based component. |
General |
              Keep component as in CAD (default if
                  CreationType=TreeOfComponents). |
Components |
              Generate JT component-based components. |
on |
              Treat each polynomial segment as a straight line segment. This is necessary for reading some VDAFS files, COMPUTERVISION CADDS 4X in particular. |
off |
              Treat each polynomial as found in the CAD file (default). |
on |
                 Read tags of supported entities as metadata (default).
off |
              Do not read tags. |
CAD units |
              Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
              Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
              Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
              The reader considers this tolerance as the object space tolerance used to process the CAD data. The default value is 0.01. |
Supported Metadata
| Type | Entities | Description |
string |
              Hierarchy of an entity within a part. Generated when
string |
                 points lines surfs  |
                 The tag (name) of the entity as read from the CAD model, if one exists. Generated when   |
