STEP Reader
Supported Entities
- Coordinate systems
 - Free points
 - Free curves
 - Surfaces
 - Quilt bodies
 - Solid bodies
 - Facets/triangles
 - Assemblies
Entities with non-latin characters in their names are supported.
Import Options
| Value | Description |
on |
                 Import all generic attributes (global and related to single entities) as metadata.  |
off |
              Do not import attributes related to single entities. Only import global attributes. |
%attribute1%attribute2%attribute3 |
                 Import specified generic attributes as metadata. The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. MotionView will recognize it as it is the first character of the string.  |
on |
              Avoid using the conversion functions provided by third-party (default). |
off |
              Use the conversion functions provided by third-party. |
on |
              Assign body identifier as
                metadata.
off |
              Do not assign body identifier as metadata (default). |
double |
              A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
integer |
                 Read color attributes of geometric entities as metadata with integer values.
real |
                 Read color attributes of geometric entities as metadata with real values.
on |
                 Same as
off |
              Do not read color attributes (default). |
Parts |
              Generate a full part-based hierarchy. |
BOMOnly |
              Generate an empty part-based hierarchy. |
TreeOfComponents |
              Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
              Consolidate hierarchy into a single part. |
on |
                 Read density value as metadata (default).
off |
              Do not read density value. |
on |
              Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
              Merge edges together during the import cleanup phase (default). |
on |
                 Generate the full CAD name, as retrieved from the CAD part, as metadata. This consists of assembly name/part name/feature name/entity name.
off |
              Do not generate full name metadata (default). |
on |
              Import entities that are hidden, blanked, or no show. |
off |
              Do not import entities that are hidden, blanked, or no show (default). |
on |
              Import CAD coordinate systems as system collectors (default). |
off |
              Do not import CAD coordinate systems. |
on |
                 Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.  |
off |
              Import the model in the normal fashion (default). |
on |
              Import free curves (wireframe entities) into the model (default). |
off |
              Do not import free curves. |
on |
              Import free points into the model (default). |
off |
              Do not import free points. |
on |
              Read layer value as metadata.
off |
              Do not read layer value (default). |
on |
              Generate metadata with the original CAD hierarchy within the
                part.
off |
              Do not generate metadata with the original CAD hierarchy within the part (default). |
string |
              Name of the CAD attribute containing the PDM material name info of the current
                  part. Default is "Material".  |
string |
              Name of the CAD attribute containing the PDM mesh flag name info of the current
                  part. Default is "MeshFlag".  |
string |
              The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details.  |
string |
              Name of the CAD attribute containing the PDM material ID info of the current
                  part. Default is "MID".  |
on |
              Import original CAD entity IDs as
                metadata.
off |
              Do not import original CAD entity IDs as metadata (default). |
string |
              Name of the CAD attribute containing the PDM part number info of the current
                part.  Default is "PartNumber”.  |
string |
              Name of the CAD attribute containing PDM property ID info of the current
                  part. Default is "PID”.  |
string |
              Name of the CAD attribute containing PDM major revision info of the current
                  part. Default is "Revision”.  |
double |
              Define the model scaling factor during import. Default is 1.0.  |
on |
              For trimmed surfaces, shrink the corresponding base surfaces to only enclose the extents of the external trimming contour, plus a narrow frame. |
off |
              Do not modify the base surfaces (default). |
on |
              Read surfaces, but do not create solid entities. |
off |
              Create solid entities (default). |
Body |
              Generate body-based component (default if
                  CreationType=Parts). |
Layer |
              Generate layer-based component. |
Part |
              Generate part-based component. |
General |
              Keep component as in CAD (default if
                  CreationType=TreeOfComponents). |
on |
                 Create one component per third-party body. There might be one or more third-party bodies per third-party component. This option cannot be used when   |
off |
              Do not consider the division of third-party components into third-party bodies while creating components (default). |
on |
              Stitch surfaces belonging to different components. |
off |
              Do not stitch surfaces belonging to different components (default). |
on |
                 Create entity name as metadata (default).
FromBody |
                 Take entity from its parent body and create as metadata.
off |
              Do not read tags. |
CAD units |
              Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
              Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
              Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
string |
              Name of the CAD attribute containing the PDM thickness info of the current
                  part. Default is "Thickness".  |
string |
              Name of the CAD attribute containing the PDM UID info of the current
                  part. Default is "UID".  |
Supported Metadata
| Type | Entities | Description |
string |
              Identifier of the CAD body containing the entity. Generated when
string |
              comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts |
                 Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model. Generated when   |
double |
              solids |
                 The value of the density of a solid. Generated when   |
string |
                 points lines surfs solids comps assems  |
                 A string indicating the name in the following format:
 Generated when   |
integer |
              Value of the layer of an entity. Generated when
string |
              Hierarchy of an entity within a part. Generated when
integer |
              comps if hierarchy as Assemblies; parts if hierarchy as Parts |  Model units specified in the CAD file.
 This is always generated.  |
string |
                 points lines surfs solids parts  |
                 The original CAD entity ID. Generated when   |
string |
                 points lines edges surfs solids  |
                 The tag (name) of the entity as read from the CAD model, if one exists. Generated when   |
