Inspire Reader
Supported Entities
- Models
 - Assemblies
 - Parts
 - Solids
 - Sheets
 - Curves
 - Points
 - Axis Systems
 - Facets/Triangles
 - FE Models
 - Alternatives
- Active alternatives are imported by default.
 - All alternatives are imported when hidden (blanked/no show) entities are imported.
- Visibility
 - Color
 - Transparency
 - Active status
- Active geometry is imported by default.
 - All geometry is imported when hidden (blanked/no show) entities are imported.
Import Options
| Value | Description |
on |
              Assign body identifier as
                metadata.
off |
              Do not assign body identifier as metadata (default). |
double |
              A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
integer |
                 Read color attributes of geometric entities as metadata with integer values.
on |
                 Read color attributes of geometric entities as metadata.
off |
              Do not read color attributes (default). |
Parts |
              Generate a full part-based hierarchy. |
BOMOnly |
              Generate an empty part-based hierarchy. |
TreeOfComponents |
              Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
              Consolidate hierarchy into a single part. |
on |
                 Read density value as metadata (default).
off |
              Do not read density value. |
on |
              Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
              Merge edges together during the import cleanup phase (default). |
on |
              Extract the manifold body from a Parasolid general body that is non-manifold and/or of mixed topological dimensionality (default). |
off |
              Extract Parasolid general bodies as defined. |
on |
              Import entities that are hidden, blanked, or no show. |
off |
              Do not import entities that are hidden, blanked, or no show (default). |
on |
              Import FE mdoels (default). |
off |
              Do not import FE models. |
on |
                 Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.  |
off |
              Import the model in the normal fashion (default). |
on |
              Import free curves (wireframe entities) into the model (default). |
off |
              Do not import free curves. |
on |
              Import free points into the model (default). |
off |
              Do not import free points. |
on |
              Generate metadata with the original CAD hierarchy within the
                part.
off |
              Do not generate metadata with the original CAD hierarchy within the part (default). |
string |
              The string is prefixed to all metadata names. No prefix is used by
                  default. See CAD Metadata Naming for more details.  |
on |
              Import original Inspire and Parasolid entity IDs as metadata. |
off |
              Do not import original Inspire and Parasolid entity IDs as metadata (default). |
double |
              Define the model scaling factor during import. Default is 1.0.  |
on |
              Read surfaces, but do not create solid entities. |
off |
              Create solid entities (default). |
Body |
              Generate body-based component (default if
                  CreationType=Parts). |
Part |
              Generate part-based component. |
General |
              Keep component as in CAD (default if
                  CreationType=TreeOfComponents). |
Components |
              Generate JT component-based components. |
on |
              Split periodic surfaces to improve the quality and robustness of the import (default). |
off |
              Import periodic surfaces as a single surface with a seam edge. |
CAD units |
              Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
              Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
              Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
on |
off |
Supported Metadata
| Type | Entities | Description |
string |
              Identifier of the CAD body containing the entity. Generated when
string |
              comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts |
                 Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model. Generated when   |
double |
              solids |
                 The value of the density of a solid. Generated when   |
string |
              Hierarchy of an entity within a part. Generated when
integer |
              comps if hierarchy as Assemblies; parts if hierarchy as Parts |  Model units specified in the CAD file.
 This is always generated.  |
string |
                 comps points lines surfs solids parts  |
                 The original Inspire ID for comps and the Parasolid entity IDs for the geometry. Generated when   |
string |
                 points lines surfs solids  |
                 A combination of the Inspire body ID and the Parasolid entity ID. Generated when   |
