CATIA Composites Link Reader
Use the CATIA Composites Link option to import drape data. This method is separate from the CATIA reader, where drape data is not imported.
- Import a CAD model (without composite data) using the CATIA geometry import method.
 - Use the CATIA Composites Link connection to import the HDF5 files created from the Simulayt interface in CATIA.
 - When realizing the plies, use the CATIA Composites Link drape map by proximity method in the Ply Realization dialog.
 - When exporting the composite data to CAD including draping, use the geometry export option CATIA Composites.
