CAD Import
Learn about the supported CAD readers and the options available for importing CAD geometry data.
CAD readers are dynamically loaded upon demand.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
CAD readers supported by the application.
CAD readers provide options for processing data during import.
Each reader reads the CAD file and stores the geometry information. When a CAD file is read, a .msg file is created (or appended to) in the current working directory.
Learn about possible difficulties you may encounter during CAD import.
The metadata names generated by the CAD readers are composed of a general prefix followed by a metadata specific name.
The prefix is specified using the @MetadataPrefix
option in each _reader.ini file.
Import FE models for supported solver interfaces.
Learn about importing connector files.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in the application.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Templates can be imported by means of the File > Import menu.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
ON THIS PAGE
@MetadataPrefix
option in each _reader.ini file.ON THIS PAGE
