Plies defined by geometry.
            Plies can be defined by geometry. Options include:
                    - Lines – closed loop of lines which specify the boundary of the ply.
                    - Surfaces – list of surfaces which make up ply.
                    - Solids – list of solids which make up ply. Only supported for the Core ply
                        type.
            When a mesh is available, ply shapes defined by geometry are converted to shapes
                defined by element sets by performing a realization on the ply. To perform a ply
                realization:
                In the Model Browser, right-click on a ply.
                Select Ply Realization from the context menu.
The Ply Realization dialog displays.
                Set options according to the table below.
| Option |
Action |
                        | Realization Region |
                        Region to which ply should be realized. Options include:
                                - Component(s) that contain elements
                                - Elements
                        | Projection options |
                        Determines the method of projection to elements. Use Project normal
                            to target mesh except in cases where FiberSim, CATIA Composites Link, Kinematic drape or
                            Pamformh5 data has been imported.
                                - Project normal to target mesh for CPD/Geom data
                                - FiberSim drape map by proximity
                                    method
                                - CATIA Composites Link drape map
                                    by proximity method
                                - Pamformh5 map by proximity method
                                - Kinematic draping map by proximity method
                        | Search criterion |
                        Determines how elements on the boundary of geometry are selected.
                            Options include:
                                - Element centroid – if centroid is within ply geometry, element
                                    used in ply
                                - All element nodes inside – if all element nodes within ply
                                    geometry, element used in ply
                                - Shrinkage factor of border element edges - if the fraction of
                                    the element area is intersected by the ply boundary, element
                                    used in ply
                        | Tolerance |
                        Tolerance on distance between geometry ply and elements that have
                            been selected in realization region. If distance is larger than
                            tolerance, elements are not added to ply. |
                        | Input sample point |
                        Should only be used if ply realization fails or is incorrect. Used
                            as an aid to determine which elements reside within ply boundary,
                            particularly for curved surfaces. If input sample point is used, plies
                            should be realized one at a time.  |
