Transformations
Transformation entities define solver transformations, and are used to define a transformation sequence in a Position entity, to be applied on a set of nodes or on a SolverSubmodel.
Abaqus
| Card | Description |
| *NMAP | Maps nodes from one coordinate system to another, and rotates, translates, or
                  scales the nodal coordinates. Note: More than one transformation can be applied on
                    a given node set using additional *NMAP keywords.
                A given transformation can be applied multiple times using separate *NMAP keywords for each required instance. The coordinates for Point A and Point B cannot be the same. If the Magnitude is greater than 0, the nodes will be translated in the direction of the vector AB; if the Magnitude is less than 0, the nodes will be translated in the opposite direction of the vector AB. If the Magnitude is equal to 0, an error message will be issued when the transformation is applied. A positive angle results in a counter clockwise rotation; a negative angle results in a clockwise rotation. If the Angle is equal to 0, an error message will be issued when the transformation is applied. If the scale factor along the X, Y, and Z axes are uniform, then the Uniform Scale checkbox can be selected and one Scale size can be specified. If the scale factor is different along each axis, then it can be entered separately by clearing the Uniform scale checkbox.  |
Radioss
| Supported Card | Solver Description |
| //SUBMODEL | Defines a part of the model with separate definition of numeration, unit system and Radioss version. |
| /TRANSFORM/TRA | Defines a translation for a set of nodes or a submodel. A transformation cannot be applied on a node set and a submodel using the same keyword.  |
| /TRANFORM/ROT | Defines a rotation for a set of nodes or a submodel. A transformation cannot be applied on a node set and a submodel using the same keyword.  |
| /TRANFORM/SCA | Defines scaling factors in X,Y,Z directions for a set of nodes. |
| /TRANSFORM/SYM | Defines a symmetry on a set of nodes, normal to the plane defined by a vector. |
