Charts
Chart entities plot X and Y data in the form of raw values. They also plot tables created in HyperMesh with the Matrix Browser or results data loaded for post-processing.
Create and Edit Charts
                In the Model Browser, right-click and select Create > Chart > Line Chart.
                A new chart is added to the entity list.
 - Use the Entity Editor to specify the name of the chart.
                Select a data source.
- Direct Input
 - Click
 and manually enter X and Y values for
                                the line chart. -
                                Tip:
- Right-click on any cell in the Direct Input table to
                                            import or export CSV data.
For import, the CSV file is expected to have data already sorted in 2 columns only and rows having only numeric data. The following data may be omitted from the import operation: Rows with any blank cells or alpha-numeric characters, rows having duplicate data on the X axis, or any columns.
 - Right-click on any cell in the Direct Input table to copy and paste data. You can also use the standard Ctrl + C and Ctrl + V shortcuts.
 - You can add more points to a curve in between existing points by selecting their corresponding data row in the table and right-clicking on the row number to Insert Above or Below the current row of data.
 - HM Table
 - Use the Table selector that appears below to select a Table entity already created in HyperMesh. This could be a table created using the Matrix Browser. In the fields that appear under X axis and Y axis, select the appropriate X column and Y columns from the table respectively.
 - Results
 - Use the entity selector that appears to select Elements or Nodes. X-axis data is already assumed as Entity ID. Choose an appropriate data type and component for results to be plotted on the Y axis of the chart.
                To plot a Chart:
- Double-click the Chart entities in the Model Browser to open the Chart Browser.
 - Highlight the name of the Chart you want to plot from the list.
                        Right-click and select Review.
                        The chart is plotted in a pop-up window.
 - Optional: To view the data plotted in the Chart preview, right click in the chart preview and select Values.
 - Optional:
                Change various attributes of the chart in the Entity Editor.
- Symbol Style
 - Provides options for adding a symbol to the curve label. You can set the style, color, frequency, and size of the symbol.
 - Shade Area
 - Provides options for shading parts of the graph in relation to the curve.
 - Line Color
 - Change the color of the curve.
 - Line Thickness
 - Chang the thickness of the curve.
 - Line Style
 - Options for displaying various line types.
 - X-axis label
 - Overwrite the current X-axis label shown in Chart preview.
 - Y-axis label
 - Overwrite the current Y-axis label shown in Chart preview.
