Hourglass entities define hourglass and bulk viscosity properties which are referenced
    via HGID in the *PART command.
    LS-DYNA Cards
                | Card |
                Description  |
                | *HOURGLS |
                Defines hourglass and bulk viscosity properties which are referenced via HGID
                  in the *PART command |
    OptiStruct Cards
      Defines hourglass control parameters to reduce spurious zero-energy modes in elements with
        reduced integration.
                | Card |
                Description  |
                | HOURGLS |
                  elements with reduced integration |
