| *DAMPING_FREQUENCY_RANGE |
                                Provides approximately constant damping over a range of
                                    frequencies and applies damping to global motion. |
                                | *DAMPING_FREQUENCY_RANGE_DEFORM |
                                    frequencies and applies damping to element deformation. |
                                | *DAMPING_GLOBAL |
                                Define mass weighted nodal damping that applies globally to
                                    the nodes of deformable bodies and to the mass center of the
                                    rigid bodies. |
                                | *DAMPING_PART_MASS |
                                Define mass weighted damping by part ID. |
                                | *DAMPING_PART_MASS_SET |
                                Define mass weighted damping by part set ID. |
                                | *DAMPING_PART_STIFFNESS |
                                Assign Rayleigh stiffness damping coefficient by part
                                    ID. |
                                | *DAMPING_PART_STIFFNESS_SET |
                                Assign Rayleigh stiffness damping coefficient by part set
                                    ID. |
                                | *DAMPING_RELATIVE |
                                Apply damping relative to the motion of a rigid body. |
