The plug-in library supports two interpreted plug-ins based upon the Tcl and Templex
    scripting languages.
    Interpreted plug-ins are easy to author and change,
      however they may not perform as well compared to a compiled plug-in. The interpreter-based
      plug-ins support the Begin, OnRecord, and
        End events, and also have functions added to their interpreters to
      support table_info, record_info, and
        record_action functions. Unlike the C++ plug-in API, no arguments are
      passed to these events – they must call the query and action functions that added to the
        interpreter.Optional arguments may be passed from XML and queried from the plug-ins using
        the
GetOption command. This command has two forms:
          - GetOption() - returns the string passed to the plug-in by
            specifying the argument “opt_str” in the XML.
          - GetOption(key) - accepts a key value will return the value of any
            argument that is not interpreted as a functional argument, such as
              src, begin, onrecord, etc.
Option strings may contain context variables such as
@current_subcase,
@current_step, etc. The Expression Builder only supports passing
        optional arguments to a plug-in by passing values in the
“opt_str”
        argument (the 1st form).
Important: The interpreters used by Result Math scripted
          plug-ins are separate from those that are included in the application. Variables and
          procedures defined in the application are not available to the plug-in
          interpreters.
