CreatePartsFromElements
Creates parts from elements.
- elems
 - An element entity table.
Outputs
- parts
 - A part entity table.
- A model may contain elements that refer to parts with no corresponding part entity. This utility operator is used to create those parts that have not explicitly been created so that a lookup failure will not occur.
 - This operator should be called within the model/commit block to insure parts are created when a model is attached (see Globalize).
 - This operator is not available in the Expression Builder.
N/AXML Example
<call name="CreatePartsFromElements" elems="elem_tab" parts="part_tab" />
