Load a Model Only
- From the Load Model panel, activate the Load model check box.
 - If necessary, deactivate the Load results check box.
                Click the file browser button,
, next to Load
                        model and select an animation file.
                Click Apply.
                The model is loaded. A model content table is created for post-processing.
