Entity Selection
Entities can be selected using input collectors or the quick window selection method.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
Input collectors allow you to select entities in a model to which you can apply various tool functions.
Locator strings can be used to identify node/element/parts within a model.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
