Report Parameters
Multiple report parameters are supported in HyperView.
- Global (Model)
- Model Title (Hvmodel Title)
 - Loadcase ID (Hvmodel Loadcaseid)
 - Simulation index (Hvmodel Simulationindex)
 - MeshMode (Hvmodel Meshmode)
 - PolygonMode (Hvmodel Polygonmode)
 - Contour
- Data type (Hvcontourctrl Datatype)
 - Data comp (Hvcontourctrl Datacomp)
 - Legend position (Hvcontourctrl Legendposition)
 - Legend header text (Hvlegendheader Text)
 - Legend header font name (Hvlegendheader Fontname)
 - Legend header font size (Hvlegendheader Fontsize)
 - Legend footer text (Hvlegendfooter Text)
 - Legend footer font name (Hvlegendfooter Fontname)
 - Legend footer font size (Hvlegendfooter Fontsize)
 - Tensor
 - Vector
 - Deformed
- Deformed scale mode (Hvscalectrl Scalemode)
 - Deformed scale factor (Hvscalectrl Scalefactor)
 - Deformed data type (Hvscalectrl Datatype)
 - Undeformed mode (Hvscalectrl Undeformedmode)
 - Undeformed color (Hvscalectrl Undeformedcolor)
 - Tracing
- Tracing mode (Hvtracingctrl Tracingmode)
 - Tracing steps (Hvtracingctrl Tracingsteps)
 - Tracing line width (Hvtracingctrl Linewidth)
 - Tracing line color (Hvtracingctrl Linecolor)
 - Section Cut
- Section cut base coords-x (Hvsection Basecorrdsx)
 - Section cut base coords-y (Hvsection Basecorrdsy)
 - Section cut base coords-z (Hvsection Basecorrdsz)
 - Section cut color (Hvsection Color)
 - Section cut cross-section width (Hvsection Crosssectionwidth)
 - Section cut label (Hvsection Label)
 - Section cut visibility (Hvsection Visibility)
 - Measure
- Measure color (Hvmeasure Color)
 - Measure font name (Hvmeasure Fontname)
 - Measure font size (Hvmeasure Fontsize)
 - Measure font slant (Hvmeasure Fontslant)
 - Measure font weight (Hvmeasure Fontweight)
 - Measure label (Hvmeasure Label)
 - Measure visibility (Hvmeasure Visibility)
 - Measure entities (Node/Element/Part/System)
 - Measure locator1 (Hvmeasurelocator1 Locator1)
 - Measure locator2 (Hvmeasurelocator1 Locator2)
 - Measure locator3 (Hvmeasurelocator1 Locator3)
Note: The number of locators listed is dependent upon the measure type that is selected (for example, "Position" only provides one locator while "Distance Between" provides two locators). - Notes
- Note transparency (Hvnote Transparency)
 - Note x coordinates (Hvnote Xcoordinates)
 - Note y coordinates (Hvnote Ycoordinates)
 - Note z coordinate (Hvnote Zcoordinates)
 - Note x position (Hvnote Xposition)
 - Note y position (Hvnote Yposition)
 - Note border width (Hvnote Borderwidth)
 - Note horizontal alignment (Hvnote Horizontalalignment)
 - Note anchor to screen (Hvnote Anchortoscreen)
 - Note auto hide (Hvnote Autohide)
 - Note text (Hvnote Text)
 - Note color (Hvnote Color)
 - Note fill color (Hvnote Fillcolor)
 - Note label (Hvnote Label)
 - Note visibility (Hvnote Visibility)
 - Note locator (Hvnote Locator)
 - Note font name (Hvnote Fontname)
 - Note font size (Hvnote Fontsize)
 - Note font slant (Hvnote Fontslant)
 - Note font weight (Hvnote Fontweight)
 - Note entities (Node/Element/Part/System)
 - View - CurrentView
- Fit (Hvview Fit)
 - Standard View (Hvview Standardview)
 - Tracking
- Tracking entity (Hvtrackingctrl Entity)
 - Tracking label (Hvtrackingctrl Label)
 - Tracking entities (Node/Element/Part/System)
 - Tracking locator1 (Hvtrackingctrllocator1 Locator1)
 - Tracking locator2 (Hvtrackingctrllocator1 Locator2)
 - Tracking locator3 (Hvtrackingctrllocator1 Locator3)
Note: The number of locators listed is dependent upon the tracking system that is selected (for example, "Node" only provides one locator while "Plane" provides three locators).
