Opening Animation Files
Animation files are opened using the Load Model panel.
Use the Load Model tool to load model and result files.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
Entities can be selected using input collectors or the quick window selection method.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
