Load a Model and Multiple Results from Different Files
- From the Load Model panel, activate the Load model and Load results check boxes.
                Click the file browser button,
, next to Load
                        model and select an animation file.
                Click the Add multiple result file icon,
, located to the right of the
                    Load results to open the Result File List dialog.
                Click the Add result file button,
, to open the Load Results Files
                    dialog.
             - Select the desired result files using Ctrl + left click or Shift + left click, and click Open.
 - If necessary, repeat Steps #4 and #5 to add more files.
 - Click OK to exit the Result File List dialog.
                Click Apply.
                The model and the selected result files are loaded. A model content table and results table is created for post-processing.
