Post
Enhancements
- Beam Stress
- Removed the loadcase selection inside the tool, and now uses the loadcase selection from the Results Browser.
- Plot Control Entities
                            - The modelsubcase data name has been added to the subcase entity to refer to the loadcases from an analysis set up.
- The complex format has been added to the vector, tensor, and deformation plots.
- Results Query Tools
                            - Support for the "last" identifier for the step index in the XML definition instead of a specific ID.
- User Systems added to the available selection for Abaqus UP.
- An option has been added to run the XML configuration file when a model and results are available in the HyperMesh database.
- Dedicated icon added to launch the Derived Load Case workflow has been added.
Resolved Issues
- Memory build up issue on plot control definition using explicit selection of multiple components.
- Sorting by entity ID on Results Query.
- Slow frame rate on simultaneous plot of deformation and vector/tensor.
- Graphics cleanup on marker plot.
- Resolution of crash when shrink elements on with vector/deformation plot.
- Decoupling of graphic and math engine in the Free Body Plot control. Changing displayed components or arrow size no longer reevaluate the free body section forces.
