| area | Hexa (Contact) | hexa (area tie), adhesive (shell gap) |
                                            | area | Hexa (Rigid) | adhesive |
                                            | area | Spring (Contact) | type2(adhesive spring) |
                                            | seam | Beam (Contact) | mat196 |
                                            | seam | Hexa (Contact) | hexa (seam tie), hexa (adhesive contact), HC Glue
                                                Mastic sealer, HC glue spot sealer, HC glue glass
                                                adhesive, hexa (Tapered T) |
                                            | seam | Hexa (HAZ) | hexa imprint (adhesive-contact), hexa (tapered
                                                T), hexa (RBE2-RBE3) |
                                            | seam | Hexa (Rigid) | hexa (adhesive), hexa (tapered T) |
                                            | seam | Penta (HAZ) | penta imprint (adhesive-contact) T |
                                            | seam | Seam (Vectors) | seam (vectors) |
                                            | seam | Seam Quad | seam quad LTB, Seam-quad (angled+capped+L),
                                                Seam-quad (angled+capped+L), Seam-quad (vertical +
                                                angled), Seam-quad (angled) |
                                            | seam | Seam Rigid | seam rigid LTB |
                                            | seam | Spring (Contact) | type2(spring single row), type2(spring multiple
                                                row) |
                                            | spot | Beam (Contact) | Mat100, Mat196, rod(spot tie), HC beam spotweld,
                                                HC glue, HC glue structural adhesive, HC welding
                                                line, HC hemming |
                                            | spot | Beam (Rigid) | Bush, cbar (rigid) |
                                            | spot | Cfast (General) | cfast_elem (GA-GB), cfast_elem (GS), cfast_prop
                                                (GA-GB), cfast_prop (GS) |
                                            | spot | Fastener (Coincident) | Fastener |
                                            | spot | Fastener (Nodes) | fastener nodes |
                                            | spot | Fastener (Noncoincident) | fastener noncoincident |
                                            | spot | Hexa (Contact) | mat100(hexa), hexa (spot tie), HC Hexa
                                                Spotweld |
                                            | spot | Hexa (HAZ) | hexa nugget, acm (shell gap contact +
                                                coating) |
                                            | spot | Hexa (Imprint) | acm (shell gap + coating) |
                                            | spot | Hexa (Rigid) | acm (general) |
                                            | spot | Spring (Contact) | type2(spring), cbush (spot tie) |
                                            | spot | Spring (Rigid) | sealing, bush, rbe3-cbush-rbe3, rbe3-celas-rbe3,
                                                cbush (rigid) |
