Composites
New Features
- Load Response Through Thickness Plots Support Multi-Selection
- This allows for easy comparison of different stresses, load cases, or
                                elements/laminates.
Enhancements
- Injection Mold Mapping
- Abaqus solver support for injection mold mapping on shell elements.
- OptiStruct and Nastran Profiles
- MAT2 material card is supported for material engineering constants analysis.
- Constants Table and Plot Results
- The number of elements for engineering constants table and plot results is now limited to 1000.
- Laminate Data Section Harmonized
- The laminate data section in all laminate analyses has been harmonized.
Known Issues
- There are performance issues on ply stacking in larger models.
- There are performance issues in models with many laminates.
- Derived load cases are not yet supported in composite stress toolbox.
- Load response contouring does not fully support symmetric laminates. While element contour already takes symmetry into account fully, the ply wise result selection is still lacking the symmetric layers.
- Contouring load response for PCOMPG relies on layer index instead of global ply ID.
- Error messaging for analysis of elements with PSHELL property lacks details for some corner cases.
Resolved Issues
- Performance improvements have been made for ply visualization in large models.
- The Material Orientation tool now creates non orthogonal systems on certain models with "Curve" method.
- Segmentation fault when reviewing ply with detailed thickness and layers on, then turning detailed thickness off has been resolved.
- Solid ply shape realization data not being output to table has been resolved.
- Ply sets empty after Ansys property absorb has been resolved.
- Elements are now highlighted when selected for detailed results from composite stress toolbox contour results.
- The *compositeanalysis command theta option now supports real values instead of integer to allow rotations lower than one degree.
- Ply realization with kinematic drape method (applying a drape table’s information to a different mesh or ply) now assigns thickness information correctly and shows corresponding status message.
