HyperCrash
.mcrash File
.mcrash File
Previous topic Next topic Expand/collapse all hidden text
.mcrash File
Header
The first line of the .mcrash file will be:
#MCRASH_GLOBALFILE
Where:
Unit
•#MCRASH_GLOBALFILE
is a keyword
Keyword
No
This line will be followed by:
/MODEL/model_title
Where:
Unit
•MODEL
is a keyword
Keyword
No
•model_title
is a name of the model
String
No
Hierarchy: assembly
The hierarchy of the model will be described by the appropriate number of the following lines:
/TREE/ASSEMBLY/assembly_id/assembly_title
Where:
Unit
•TREE
is a keyword
Keyword
No
•ASSEMBLY
is a keyword
Keyword
No
•assembly_id
is the identifier number of the assembly
Integer
No
•assembly_title
is the name of the assembly
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nbchild
In the following lines we have Nbchild (Integer) representing IDs of Assemblies, Physical Parts, or Subparts.
Card 2:
1
2
3
4
5
6
7
8
9
10
Child1
Child10
Child_ Nbchild
/TREE/HPART/hpart_id/NAME
Where:
Unit
•TREE
is a keyword
Keyword
No
•HPART
is a keyword
Keyword
No
•hpart_id
is the identifier number of the HPART
Integer
No
•NAME
is the name of the HPART
String
No
Note:
•It must be the same as the one defined in the corresponding .mesh file.
•Two assemblies cannot share the same ID.
•One assembly and one physical part cannot share the same ID.
•Two physical parts cannot share the same ID.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/TREE/ASSEMBLY/6/SEAT_L_COMP
     25
     58      59      60      61      62      63      64      65      66      67
     68      69      70      71      72      73      74      75      76      77
     78      79      80      81      82
/TREE/HPART/7/STIFF_RR_LWRARM_L
/TREE/HPART/8/MEMBER_ENG_CRADLE
Theoretical mass of each part
For each physical part, we must have the following line in the file:
/MASS/part_id/mass_value/unit
Where:
Unit
•MASS
is a keyword
Keyword
No
•part_id
is the identifier of the part (HPART or SUBPART)
Integer
No
•mass_value
is the mass value of the HPART or SUBPART defined by part_id
Real
Mass
•unit
is a keyword which defines the unit and can be:
•kg
•g
•t        ( 1 t = 1000 kg)
•hunit        ( 1 hunit = 9800 kg)
String
No
/MASS/1345/12.0567/hunit
/MASS/1365/56.00/g
/MASS/1/.0001/t
Total Mass and center of gravity
The total theoretical mass of the car must be given to the keyword:
/TOTALMASS/mass_value/unit
/FRONTMASS/mass_value/unit
/REARMASS/mass_value/unit
Where:
Unit
•TOTALMASS
is a keyword
Keyword
No
•FRONTMASS
is a keyword
Keyword
No
•REARMASS
is a keyword
Keyword
No
•mass_value
is the theoretical mass value
Real
Mass
•unit
•kg
•g
•t        ( 1 t = 1000 kg)
String
No
/TOTALMASS/1650.0000/kg
/FRONTMASS/800.0000/kg
/REARMASS/850.0000/kg
Center of gravity
The theoretical coordinates of the center of mass are to be defined by the following block:
/CENTERG/unit
Where:
Unit
•CENTERG
is a keyword
Keyword
No
•unit
is a keyword which defined the unit and can be:
•kg
•g
•t        ( 1 t = 1000 kg)
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Xg
Yg
Zg
Where:
Unit
•Xg
Are the coordinate values of the center of mass in the global coordinate system.
Real
Length
•Yg
Real
Length
•Zg
Real
Length
End of the file
End of input data is signalled with:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
Go to
Spotwelds
Bolts
Glue
Weldline
Hemming
Specific HyperCrash Input Files
