HyperCrash
Bolt
Bolt
Previous topic Next topic Expand/collapse all hidden text
Bolt
/BOLT/Bolt_id/Bolt_name/Type
Where:
Unit
•BOLT
is a keyword
Keyword
No
•Bolt_id
is the identifier number of the bolt
Integer
No
•Bolt_name
is the name of the bolt
String
No
•Type
is the flag of the bolt (Integer):
•1: rigid bold
•2: deformable (with spring)
•3: deformable (with spring and property)
Integer
No
Card 1 and 2: bolt size
1
2
3
4
5
6
7
8
9
10
X_center
Y_center
Z_center
Diameter
Xdir
Ydir
Zdir
L1
L2
Where:
Unit
•X_center
is the global coordinate value of the geometrical center of the bolt.
Real
Length
•Y_center
Real
Length
•Z_center
Real
Length
•Diameter
is the diameter of the bolt
Real
Length
•Xdir
is the bolt direction vector coordinates along X
Real
Length
•Ydir
is the bolt direction vector coordinates along Y
Real
Length
•Zdir
is the bolt direction vector coordinates along Z
Real
Length
•L1
is search distance in negative direction on the axle of the bolt
Real
Length
•L2
is search distance in positive direction on the axle of the bolt
Real
Length
bolt_dir
Card 3 and 4: parts list of the set 1
1
2
3
4
5
6
7
8
9
10
Npart1
Part1_1
Part1_2
Part1_10
Where:
Unit
•Npart1
is the number of part in the set 1
Integer
No
•Part1,i
are the identifier number of the part of the set 1 (10 parts per line).
Integer
No
Card 5 and 6: parts list of the set 2
1
2
3
4
5
6
7
8
9
10
Npart2
Part2_1
Part2_2
Part2_10
Where:
Unit
•Npart2
is the number of part in the set 2
Integer
No
•Part2,i
are the identifier number of the part of the set 2 (10 parts per line).
Integer
No
Card 7: Only if TYPE = 3
1
2
3
4
5
6
7
8
9
10
< full path > prop_file_name
Where:
Unit
•< full path > prop_file_ name
is the full path and file name of the spring property of the bolt
String
No
In case <full path> is not defined, the prop_file_name will be read in the directory, $MCRASHDIR/property.  Variable (like $MCRASHDIR) can also be used to defined the path.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/BOLT/2/Front subframe fixation/1
       -678.822        -449.455          301.25       50.000000
        .000000         .000000         1.00000       100.00000       120.00000
      3
     10      12      13
      2
     11      21
/BOLT/2/Front subframe fixation/3
      3
     10      12      13
      2
     11      21
$MCRASHDIR/my_bolt/bolt_256.prop
See also
.mcrash File
