HyperCrash
Glue
Glue
Previous topic Next topic Expand/collapse all hidden text
Glue
/GLUE/glue_type/Nb_pt/Glue_id
Where:
Unit
•GLUE
is a keyword
Keyword
No
•glue_type
is keyword which defined the glue type:
•AUTO: automatic glue
•LINE: glue defined with a line
•AREA: glue defined with a contour line
Keyword
No
•Nb_pt
is the number of geometrical points defining the surface glued
Integer
No
•Glue_id
is the identifier number of the glue
Integer
No
Card 1: Set of part
1
2
3
4
5
6
7
8
9
10
Part_1
Part_2
Gap
Property_name
Where:
Unit
•Part_1
is the identifier number of the first part to weld
Integer
No
•Part_2
is the identifier number of the second part to weld
Integer
No
•Gap
is the distance value to search the connection
Real
No
•Property_name
is the file name of the springs property of the glue. The spring property file should be stored in the directory $HCRASHDIR/property (text).
String
No
Card 2: coordinates
This card has to be defined only for type = LINE or AREA
1
2
3
4
5
6
7
8
9
10
X1_1
Y1_1
Z1_1
X2_1
Y2_1
Z2_1
X1_I
Y1_I
Z1_i
X2_I
Y2_I
Z2_i
X1_nbr_pt
Y1_nbr_pt
Z1_nbr_pt
X2_nbr_pt
Y2_nbr_pt
Z2_nbr_pt
Where:
Unit
•xi_j
Global Coordinates of points defining the position of the glue for both parts or subparts to weld: one Card for each point.
Real
Length
•yi_j
Real
Length
•zi_j
Real
Length
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/GLUE/LINE/3/16
      3       4        0.000000SPRI_13_Glue
      25.271300       46.455500        0.000000
      25.271300       46.455500        5.000000
      35.271300       46.455500        0.000000
      35.271300       46.455500        5.000000
      45.271300       46.455500        0.000000
      45.271300       46.455500        5.000000
/GLUE/AREA/4/17
      31.000000       62.000000        0.300000
      31.000000       62.000000        7.000000
      31.000000       47.000000        0.500000
      31.000000       48.000000        8.000000
      50.000000       34.000000        0.000000
      50.000000       33.000000        7.000000
      68.000000       56.000000        0.400000
      68.000000       58.000000        7.000000
/GLUE/AUTO/0/18/automatic glue
      3       4        20.00000SPRI_13_Glue
See also
.mcrash File
