HyperCrash
Spotwelds
Spotwelds
Previous topic Next topic Expand/collapse all hidden text
Spotwelds
/SPOTWELD/Nb_part/id
Where:
Unit
•SPOTWELD
is a keyword
Keyword
No
•Nb_part
is the number of part or subpart to weld (Integer < 6)
Integer
No
•id
is the identifier number of the spotweld
Integer
No
Card 1: coordinates
1
2
3
4
5
6
7
8
9
10
x_I
y_I
z_I
Where:
Unit
•x_I
Global Coordinates of points defining the position of the spotweld for each part or subpart to weld: one Card for each point. Nbpoint card has to be defined.
Real
Length
•y_I
Real
Length
•z_I
Real
Length
Card 2: Part id or subpart id
1
2
3
4
5
6
7
8
9
10
part_1
part_Nbpoint
Where:
Unit
•part_I
is the identifier number of the parts to weld
Integer
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/SPOTWELD/2/3
       -678.822        -449.455          301.25
      1       2
See also
.mcrash File
