EN Card
The EN card indicates the end of the input file. It is essential and has no parameters.
On the Home tab, in the Structure group,
click the
End model (EN) icon.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application that allows you to create models, get hold of simulation results and model configuration information and much more.
Each geometry and calculation request are entered on a separate line in the .pre and are referred to as cards.
Geometry cards are used to create geometry and are placed before the EG card in the .pre file.
Control cards are used to specify requests and solver settings and are placed after the EG card in the .pre file.
These cards define the type of excitation (source) as well as other relevant parameters.
The A0 card defines a linearly polarised incident plane wave.
This card defines a voltage source that is placed on a wire segment.
With this card a voltage source is placed at a node between two segments or between a segment and a triangle, ground plane or polygonal plate. It is mostly used to feed wires attached to plates.
This card realises excitation by a magnetic ring current (TEM-frill) on a segment. It gives an an accurate model of a coaxial feed, but requires both the inner and outer radii.
This card specifies excitation by an electric Hertzian dipole
This card specifies excitation by an elementary magnetic Hertzian dipole.
This card specifies a voltage source on an edge between two triangles or at a connection between a single triangle and a PEC ground plane or UTD plate.
This card is used to create a FEM modal excitation, which is the fundamental mode of the associated, infinitely long guided wave structure of the modal port.
This card inputs data from a .rsd file containing the geometry of a transmission line or PCB structure and the current distribution along this line or on the PCB for one or more frequencies.
This card specifies an excitation at an edge between triangular surface elements.
This card defines a uniform electric current filament impressed between two arbitrary points inside of the FEM region (it does not have to coincide with the edges of tetrahedra). This can be used to excite for instance a patch antenna.
This card defines an impressed current source that varies linearly between the values at the start and end points.
This card uses current data calculated for a PCB as an impressed current source. The data is read from an Altair PollEx .rei file.
This card defines a voltage source to a radiating cable with or without irradiation considered.
This card uses model solution coefficients to define an impressed current source. The data is read from a .sol file or from a previous AM card.
This card defines a voltage source that can be added to any port of a general non-radiating network and that does not have a connection to geometry.
This card defines a planar, cylindrical or spherical aperture of measured or calculated field values that is converted by PREFEKO internally into an equivalent array of electric and magnetic dipoles (A5/A6 cards).
This card uses the radiation pattern of an antenna as an impressed source. The data is read from file or defined in the .pre file.
The AS card defines an excitation by means of impressed spherical modes which are either radiating (propagating in positive r direction to infinity, with r being the radius in a spherical coordinate system) or incident onto a structure (propagating towards the origin r = 0).
This card defines a voltage source that is applied to a voxel mesh in connection with a finite difference time domain (FDTD) method.
This card defines an impressed current source similar to the AI card but that makes electrical contact with a conducting surface.
The AW card is a two line card which is used to define a waveguide port excitation. With this card a waveguide port excitation by an impressed mode on a rectangular, circular, or coaxial waveguide, can be modelled or the impressed travelling modes in all waveguides of a multi-port network can be imported from a .fim file.
This card defines a ground plane with the reflection coefficient approximation (at z = 0). All computations that follow this card will include the ground plane.
The CA card is used to define a section of a shielded cable which is used for irradiation (for example, computing induced currents and voltages at the cable terminals) due to external sources. Transmission line theory is applied, for example, no need to discretise the cable as with the MoM. A section is defined as a straight part of a cable (one cable can consist of multiple sections).
This card defines a cable cross section.
This card sets the type of integral equation for perfectly conducting metallic surfaces.
The CG card defines the method to solve the matrix equation.
The CI card is used to define interconnections and terminations between cables.
The CM card is used to couple Feko with the transmission line simulation programs CableMod or CRIPTE or the PCB tool PCBMod to calculate the coupling of electromagnetic fields into transmission lines. (The AC card is used for the case of radiation by these lines.)
This card specifies a dielectric or magnetic coating of wire segments or triangular surface elements.
This card specifies the orientation of a 3D anisotropic medium.
This card defines a cable path as well as the centre or reference location to which a cable cross section definition is applied.
This card controls the export of data to additional ASCII files. For example the currents can be exported to the .out file or S-parameters can be exported to a Touchstone file.
This card can be used to define the frequency dependent or independent material characteristics of a dielectric medium, metallic medium or an impedance sheet.
This card is used to define an isotropic or anisotropic layered medium by specifying the label of the material to be used for each layer.
The EE card requests an a-posteriori error indicator whereby Feko can test the solution against an unconstrained physical test. The result is to give an indication of the region where local mesh refinement should be considered.
This card sets the solver settings for the finite difference time domain (FDTD) solver.
This card controls the calculation of near fields.
This card controls the calculation of the far fields in spherical or Cartesian coordinates.
The FR card sets the frequency/frequencies (in Hz), at which the solution will be obtained.
This card includes the complexities of dielectric environments using special Green's functions. The Green's functions relates the fields in space to the sources.
The KC card facilitates the transferral of connector names from CADFEKO to POSTFEKO.
The KS card facilitates the transferral of signal names from CADFEKO to POSTFEKO.
This L2 card places a load (complex impedance) on a node.
The LC card specifies complex, series and parallel circuits applied between connector pins and also between a connector pin and ground.
This card specifies a distributed resistive, capacitive or inductive loading or a series combination of these loads for a segment(s).
This card specifies complex series and parallel circuits applied to an edge between surface triangles.
This card impresses a complex impedance between two points inside a FEM mesh.
This card defines a complex load to any non-radiating network port that is not connected to geometry (that is any non-radiating network of the type Internal).
This card assigns a parallel circuit of discrete elements to a segment.
This card assigns a series circuit of discrete elements in series to a segment.
This card assigns a resistor, inductor or capacitor in series to a voxel mesh for the finite difference time domain (FDTD) method.
This card can be used to assign a complex impedance to a segment.
This card exports the model and solution coefficients to a .sol file.
This card defines a linear non-radiating network.
This card specifies an offset for the origin of the coordinate system for near and far field calculations. It also facilitates using only a part of the structure through label selection when calculating fields.
This card can be used to calculate the weighted set of orthogonal current-modes which are supported on a conducting surface.
With this card the currents on the surfaces and the segments can be extracted.
This card defines the phase shift of the excitation between one unit cell and the next for periodic boundary conditions. The unit cell for a PBC calculation is specified with the PE card.
This card defines a voltage or current probe along a cable.
This card is for general program control such as storing the currents for re-use in a subsequent version of the model in order to save runtime.
The PW card specifies the radiated power or the source power. It can also be used to consider mismatch.
This card defines an ideal receiving antenna that can be placed anywhere in the model.
This card controls calculations of the specific absorption rate (SAR) in a dielectric.
This card specifies an external magnetostatic bias field applied to a 3D anisotropic medium (ferrite).
This card defines a SPICE circuit that can be used when defining a load.
This card defines the impedance or admittance of an individual cable shield layer. The shield layers are used when defining a cable shield (SH card).
This card defines a cable shield consisting either of a single layer or two layers.
This card defines a skin effect, ohmic losses or an arbitrary user defined impedance boundary condition on wire segments and surface elements. Layered dielectrics can also be defined.
This card defines an S-parameter (S-matrix) request for active sources.
This card connects a non-radiating transmission line between Feko geometry or other general non-radiating networks or transmission lines.
This card is used to calculate the transmission and reflection coefficients for a plane wave interacting with a planar structure.
This card is used to define the dielectric properties of each of the windscreen glass layers. These layers are placed over the antenna elements by defining the relative position of the top layer to the reference plane.
A collection of how-tos are included that covers advanced concepts.
When meshing a model, you can either use the automatic meshing algorithm to calculate the appropriate mesh settings or you can specify the mesh sizes. When you specify the mesh sizes, the mesh sizes should adhere to certain guidelines.
Feko makes use of a local peak SAR algorithm.
Control the execution of Feko by specifying the memory management and environment variables.
The .mat file, .lud file and .rhs file are not generated by default, but can be read externally.
Feko integrates with various products within HyperWorks such as HyperStudy. Integration with third-party products is also supported through the powerful scripting and plug-in infrastructure.
Use the correct structure, convention and syntax for a SPICE circuit definition in Feko.
View the list of commonly used acronyms in Feko.
Feko creates and uses many different file types. It is useful to know what is stored in the various files and weather they were created by Feko and if it is safe to delete them. The files are grouped as either native files that have been created by Feko or non-native files that are supported by Feko. Non-native files are often exported by Feko even if the formats are not under the control of the Feko development team.
A list of notes, errors and warnings are provided as reference and to provide more information regarding the reason for the message and how to resolve the problem in the model.
click the
