SimpleCylinder
HydraulicsByFluidon/Components/Base
Simple model of a cylinder with Stribeck friction.
mo_pistonDiameter | pistonDiameter | Piston diameter | Scalar | |
mo_rodDiameterA | rodDiameterA | Rod diameter @ port A | Scalar | |
mo_rodDiameterB | rodDiameterB | Rod diameter @ port B | Scalar | |
mo_cylinderLength | cylinderLength | Cylinder length | Scalar | |
mo_rodLength | rodLength | Rod length @ port B | Scalar | |
mo_angle | angle | Inclination angle | Scalar | |
mo_deadVolume | deadVolume | Dead volume | Scalar | |
mo_massPiston | massPiston | Piston mass | Scalar | |
mo_massCylinder | massCylinder | Cylinder mass | Scalar | |
mo_fProp | fProp | Velocity dependent friction | Scalar | |
mo_fCoulomb | fCoulomb | Constant friction: Coulomb force | Scalar | |
mo_fBreakaway | fBreakaway | Breakaway force | Scalar | |
mo_vM | vM | Velocity parameter for Stribeck friction | Scalar | |
mo_vSmall | vSmall | Scalar | ||
mo_relFricReal | relFricReal | Scalar | ||
mo_areaBore | areaBore | Scalar | ||
mo_areaRodA | areaRodA | Scalar | ||
mo_areaRodB | areaRodB | Scalar | ||
mo_areaA | areaA | Scalar | ||
mo_areaB | areaB | Scalar | ||
mo_stroke | stroke | stroke | Structure | |
mo_stroke/fixed | fixed | Cell of scalars | true | |
mo_stroke/start | start | Cell of scalars | ||
mo_relVelocity | relVelocity | relVelocity | Structure | |
mo_relVelocity/fixed | fixed | Cell of scalars | true | |
mo_relVelocity/start | start | Cell of scalars | ||
mo_pA/start | start | Cell of scalars | ||
mo_pB | pB | pB | Structure | |
mo_pB/fixed | fixed | Cell of scalars | true | |
mo_pB/start | start | Cell of scalars |
mo_relFric | relFric | if selected, relative friction is calculated based on relFricFactor | Scalar | true |
mo_relFricFactor | relFricFactor | Scalar |
mo_forwardFluidProperties | forwardFluidProperties | Forward fluid properties between ports | Scalar | true |
mo__modifiers/varname | Variable name | Cell of strings | 'aRel' | |
mo__modifiers/value | Value |
flange_c | implicit | input | 1 | |
flange_p | implicit | output | 1 | |
fluidPortA | implicit | Hydraulic port A | input | 2 |
strokeOut | implicit | Relative position of piston | output | 2 |
fluidPortB | implicit | Hydraulic port B | input | 3 |
