Use API
The ase-core-api service provides an API to access the core Edge Compute Platform services. It is available as an http(2) server and as an AMQP connection (in which case the client is responsible for supplying the callback queue and consuming the message(s)).
The callback queue has to start with "ase.callback.api." and should have a unique (random) suffix.
The Edge Compute Platform Internal Device Model uses links for REST HATEOAS. The
communication model on Edge Compute Platform uses RabbitMQ queues instead of a REST
API. In order to "translate" (mimic REST) the Message Service should be the primary
connection using the ase.exchange.api
exchange with headers
href
and requestMethod
and the message as the
equivalent of the request body.
The ase.exchange.api
exchange method uses the RPC approach (i.e.,
with callback queue and correlationId, see RabbitMQ Tutorial 6). The client is responsable for
supplying the callback queue and consuming the message(s).
Example 1
GET /things/itMmuV7uNt3onfDldnoR
Exchange | Headers | Body |
ase.exchange.api |
requestMethod=GET
Example 2
PUT /things/itMmuV7uNt3onfDldnoR/properties/temperature
"temperature": 34
ase.exchange.api |
requestMethod=PUT
{"temperature":34} |
