Edge Compute Platform
The Altair IoT Studio Edge Compute Platform is an open-architecture platform for the edge which runs on resource-constrained devices, for example, the Raspberry Pi or Intel NUC. It consists of a collection of micro-services designed to ease the process of developing for specific chip architectures, ensuring data veracity, connecting to various communication protocols, monitoring resource use, and establishing remote access with a terminal or logs.
Additional Technical Information
The services are containerized (docker) for deployment on K3s: a lightweight Kubernetes built for IoT and Edge Computing.
There are several core services that are required to run the Edge Compute Platform. Any other service is optional and adds to the functionality of the Edge Compute Platform. This creates numerous (flexible) deployment possibilities. Management is done from the cloud using Altair IoT Studio.
Inter-service communication is message based (AMQP, Advanced Message Queuing Protocol). This allows for scaling and separation of services (they can run "anywhere").
Cloud connectivity for configuration and management is not required since all can be done through the local API. For remote deployment (firewalled) the cloud service can connect to an MQTT broker and expose the API.
Device connectivity is done through "device driver services" with services written for various protocols. The device drivers are considered external to the core services and interact with the Edge Compute Platform using an API.
Plug-in or "support services" are third party services that interact with the rest of the system using the API and can subscribe to telemetry data. These services can perform calculations and publish the results as telemetry.
The Edge Compute Platform itself is written in Go but any language can be used to write new services.
Also in This Section
