Using the Cluster API Inspector
This procedure will walk you through setting up and using the API inspector.
To make the API calls click the API client button displayed on the Cluster’s Overview pane.
This will open the API Client pane where REST API calls to the Edge Compute Platform running on the Asset can be made:
See Edge Compute Platform API for details on the available API endpoints.
