Deleting an External Lookup
When you delete a lookup, all lookup parameters are deleted, and all linked fields are removed from the Monarch Classic table. Any filter, sort, calculated field, or summary definitions that rely upon the linked fields become invalid.
Go to Table Design.
Select External Lookups on the Table Design ribbon. The External Lookup window displays.
Select the External Lookup you want to edit from the External Lookup selector.
Select Delete on the Table Design ribbon
Monarch Classic deletes all lookup parameters and removes all linked fields from the Table window.
CAUTION: Monarch Classic has no undo facility. Once you select Accept on the Table Design ribbon, you cannot reverse the change.
