Button
Saves the specified settings and closes the Options window.
Discards the specified settings and closes the Options window.
Displays the Folders options.
Select this button if you wish to set default paths to folders from which report files, model files, project file, and the like should be sourced.
Displays the Input options.
Select this button if you wish to specify how to format dates, what encoding type to apply to text files, which engine to use to open MS Excel files, and the like.
Displays the View (i.e., display) options.
Select this button if you wish to specify display options for tables.
Displays the Export options.
Select this button if you wish to specify default filenames for reports, tables, and summaries, versions for legacy file types (e.g., DBF, MDB), formatting requirements for exports to Excel, and the like.
Displays the Clipboard options.
Select this button if you wish to specify copy settings.
Displays the Security options.
Select this button if you wish to apply security settings for projects, models, login credentials, passwords, and the like.
Displays the Altair Monarch Server definition window.
Select this button if you wish to define an Altair Monarch Server Library instance from which to obtain inputs and send outputs.
Displays the Time Interval options.
Select this button if you wish to specify fiscal year, calendar week, and other time options.
Displays the Advanced options.
Select this button if you wish to define autorecovery options, logging levels, redaction settings, and the like.
Displays the Cache options.
Select this button if you wish to specify a cache folder and other cache options.
Displays the Themes options.
Select this button if you wish to change the color theme of your Monarch Classic application.
Launches the Monarch Help file.
