Customizing Summary Font and Background Colors
Monarch Classic enables you to customize the colors of summary fonts and backgrounds.
  1. Go to Summary Design.
  2. Select a Summary from the Summaries selector. The Summary's properties are displayed on the Summary Window.
  3. Do one of the following:
    • If you wish to view or edit all fields, select All Fields from the Summary Design ribbon.
    • If you wish to view or edit just keys, items, or measures, select Keys, Items, or Measures respectively from the Summary Design ribbon.
  4. Select the Coloring tab.
Note:
  • On the Measures Tab, you will have Coloring and Limits tab instead of Coloring tab.
© 2025 Altair Engineering Inc. All Rights Reserved.
