           Button
           Saves the specified settings and closes the Summary Design window.
           Discards the specified settings and closes the Summary Design window.
           Adds a new summary
           Duplicates a selected summary.
           Deletes a selected summary.
           Launches the Summary Properties Definition window, which will allow you to add or modify an existing summary definition.
           Displays a list of fields from which you can select key, item, and measure fields for your summary.
           Displays a list of the fields applied to a selected summary as well as their properties, which you can modify as necessary.
           Displays the key fields applied to a selected summary as well as their properties, which you can modify as necessary.
           Displays the item fields applied to a selected summary as well as their properties, which you can modify as necessary.
           Displays the measure fields applied to a selected summary as well as their properties, which you can modify as necessary.
           Launches the Page Setup window, which you can use to configure print settings for your summary.
           Launches the Monarch Help file.
