Hyperelasticity is a type of constitutive behaviour for materials like natural rubber
that exhibit large non-linear elastic deformations. These materials return to their original
shape upon unloading, following a nonlinear stress-strain relationship.
Hyperelastic models are essential in simulating the behavior of elastomeric polymers,
rubbers, and biological tissues, which undergo significant deformations. They are
frequently used in the manufacture of gaskets and seals.Figure 1. Hyperelastic Fitting Results
Key Concepts:
Strain-Energy Density Function: The core principle of hyperelastic
models is the strain-energy density function (W), which defines the stored
energy per unit volume as a function of the deformation. Different
hyperelastic models have different forms of this function, but they all
share the goal of accurately describing the material's response to
deformation.
Constitutive Models: Several constitutive models exist to represent
hyperelastic materials, each with its own strain-energy density function.
Common models include:
Neo-Hookean Model: A simple model suitable for small to
moderate strains.
Mooney-Rivlin Model: Accounts for both the first and second
invariants of the deformation tensor, providing better accuracy for
larger strains.
Ogden Model: Uses a series of terms with different exponents
and coefficients, offering great flexibility in fitting experimental
data.
Arruda-Boyce Model: Specifically designed for polymers,
capturing the entropic elasticity of the polymer chains.
Stress-Strain Relationship: The stress in a hyperelastic material is
derived from the strain-energy density function. The relationship is
generally nonlinear and depends on the specific form of the function chosen.
For isotropic materials, the Cauchy stress tensor (σ) can be expressed in
terms of the principal stretches or the invariants of the deformation
gradient.
To illustrate the application of hyperelastic models, consider the following example
using the Treloar's data for natural rubber :
Select AMDC-Data File as the Objective
operation.
Change the Material Class to "Thermoset"
Select the default File Type, uniaxial test data
(UXT), and then click the Hyperelastic button to
import the file. The Import Hyperelastic UXT Data File dialog box is
displayed.Figure 2. Import Hyperelastic UXT Data
Select the required Hyperelastic Data Import option to import the
data. Continue with the default Engineering Stress and
Strain for this example.
Click Import File to import Trelaor's UXT data. The
Hyperelastic Fitting data is imported into the application and the plot is
displayed.Figure 3. Hyperelastic Fitting Data
Adjust the Fitting Results to read the plot curve
details. In the following example, Yeoh Model values are adjusted for
C20 and C30 parameters. Figure 4. Fitting Results for Yeoh Model
Click Save Changes to save the edits.
Click the Approve Model Fit check box to approve the
model fit data.
In the File Management pane, click File
Preview.
Click OK on the Extra Information dialog box
to continue with the default values.
Figure 5. Extra Information
The Optistruct Input card is displayed in the preview pane.
Figure 6. File Preview
One may modify the text of the model fit file to suit specific needs.
Additionally, one can adjust the units and repeat the file preview process
to view the file details in the new units.
Click Export File to export model fit data to the
Project Folder.
